I have a few DVD+R Double-Layer Discs (DVD9) and i want to know wich DVD Players those discs compatible with?
can it played in any DVD Player?
ThanX!
Results 1 to 9 of 9
No recordable DVD will ever play in any player.
https://www.videohelp.com/dvdplayers
has a column for supported media types.
/Mats -
Worth noting, is that Verbatim is regarded as the most reliable (=playable) recordable dual layer DVD there is. Verbatim seems so far ahead of the competition, it's not worth spending money on anything else for home brew dual layer Video DVD. (Just passing on what I've read here at Videohelp - no personal experience with dual layer.)
/Mats -
actually i got those discs from a friend.
I'm still considering what to spend my money on, and i dont understand whats the different between DVD+R and DVD-R?
can you tell me?
thanks! -
In the case of dual layer there is little argument opposing the premise that DVD+R DL is superior at this time.
Reported success with Verbatim is much higher than others. I still can't get SONY Ricoh media to burn to completion successfully.
Some players will read burned DL disks, and some won't. -
If you seriously want to burn dual layer DVD, you need to do 2 things.
1) Buy ONLY Verbatim DVD+R DL discs. Do NOT buy DL discs of any other company and do NOT mess with DVD-R DL.
2) Read this article
http://www.digital-digest.com/~blutach/pgcedit_guide/burning_with_pgcedit/burning_with...pgcedit_v2.htm
It tells how to use PgcEdit to make ISOs and how to use ImgBurn to burn the ISOs. If you do any other method, including using Nero, you are potentially setting yourself up for problems down the road with your discs.
How to copy DVD9 with subtitle & Burn it in DVD-/+R or DVD9
By prithvi in forum Newbie / General discussionsReplies: 15Last Post: 19th May 2010, 11:37 -
USB capture devices vs USB tuner devices...... which are better for recording?
By True Colors in forum Video Streaming DownloadingReplies: 1Last Post: 31st Jan 2010, 15:04 -
DVD9 to DVD9 2 angles layer break problem
By JoeBolden in forum DVD RippingReplies: 4Last Post: 14th Jul 2009, 19:17 -
DVD Decrypter Not Reading Devices
By JoRodd in forum DVD RippingReplies: 4Last Post: 14th Apr 2009, 13:33 -
having trouble backing up dvd9 to dvd9
By Chunking in forum DVD RippingReplies: 9Last Post: 13th Oct 2007, 20:34
