I seem to be having a problem with the sound on a captured AVI.
It seem to get the sound but then it says it can not proccess it. Any ideas what is wrong here.
If I play the orginal AVI it play ok.
Audio format is PCM.
Bit rate is 1411 kbps
Audio sample size 16 bit
Here is the output of the BeSweet log.
Using AC3enc.dll v1.20 (Feb 18 2004) by Fabrice Bellard (http://ffmpeg.org).
Manual Dynamic-Compression algorithm by LigH (author of WaveBooster).
Logging start : 03/23/07 , 23:30:58.
C:\Program Files\Avi2Dvd\Programs\BeSweet\BeSweet.exe -core( -input L:\Avi2dvd_temp\Fixed_Audio01.ac3 -output L:\Avi2dvd_temp\AudioStream 1 AC3 2CH.ac3 -logfile L:\Avi2dvd_temp\BeSweet_AudioStream 1 AC3 2CH.ac3.txt ) -ac3enc( -b 384 ) -boost( /b=1 /l=0.95 ) -shibatch( --rate 48000 )
[00:00:00:000] +------- BeSweet -----
[00:00:00:000] | Input : L:\Avi2dvd_temp\Fixed_Audio01.ac3
[00:00:00:000] | Output: L:\Avi2dvd_temp\AudioStream 1 AC3 2CH.ac3
[00:00:00:000] | Floating-Point Process: No
[00:00:00:000] +-------- AZID -------
[00:00:00:000] | Total Gain: 0.000dB, Compression: None
[00:00:00:000] | LFE levels: To LR -INF, To LFE 0.0dB
[00:00:00:000] | Center mix level: BSI
[00:00:00:000] | Surround mix level: BSI
[00:00:00:000] | Dialog normalization: No
[00:00:00:000] | Rear channels filtering: No
[00:00:00:000] | Source Sample-Rate: 48.0KHz
[00:00:00:000] +-------- BOOST ------
[00:00:00:000] | Algorithm by : LigH
[00:00:00:000] | Boost Factor : 1.0
[00:00:00:000] | Limit Factor : 0.95
[00:00:00:000] +------- AC3ENC ------
[00:00:00:000] | bitrate method : CBR
[00:00:00:000] | AC3 bitrate : 384
[00:00:00:000] | Channels Mode : 5.1
[00:00:00:000] | Error Protection: Yes
[00:00:00:000] +---------------------
Error 32: No input-data was found (wrong substream?)
Quiting...
[00:00:00:000] Conversion Completed !
Logging ends : 03/23/07 , 23:30:58.
SeeYa
Never Say Never (Romeo Void 1981)
Firefox, Thunderbird -
For whatever reason avi2dvd gives wrong stream to BeSweet. The log shows also weird settings.
Your PCM is obviously 2 channel. But the output of besweet shows 5.1 channel ac3. The input should be .wav , but it is ac3.
Now, sorry I don't know how to fix it (never used avi2dvd).
I believe the Fixed_Audio01.ac3 file is 0 Kb (fake).
problems with avi2dvd
By kayla33 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2011, 14:12 -
Avi2dvd menu problems
By bman321 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2009, 20:18 -
Problem with Background sound using AVI2DVD
By govtstooge in forum Newbie / General discussionsReplies: 3Last Post: 21st Dec 2007, 15:11 -
avi2dvd sound problems
By justmenow55 in forum Video ConversionReplies: 5Last Post: 13th Aug 2007, 03:58 -
By justmenow55 in forum Video ConversionReplies: 1Last Post: 29th Jul 2007, 12:50
