Results 1 to 17 of 17
  1. Ok, has anyone been able to do this? I'm trying to convert gotham girls but all I have ever managed to do is get audio. Super does nothing. Ideas?
  2. I get a "failed to set stream format" error
  3. What is my audio input supposed to be with that? I get no audio.
  4. Do you have option to post link to swf file or link to web site?
  5. Sure, here it is:
    http://www2.warnerbros.com/gothamgirls/play/files/GG_01.swf
    GO crazy. I get video just no audio.
  6. How do I not record the name of the window? Also, there's a choice at the beginning. I was hoping to just have it go all the way through.
  7. And select frame rate to 30 or 25
    for smooth frame capture
  8. Got it. How do i not record the pointer?
  9. awesome. Now, if there was only a way to play a batch of swf files. There's like 35 of them.
    Thanks for all the help.
  10. I don't know.
    Just record 35 times
  11. Thats what I was afraid of. I was praying for some sort of method for playing all 35 of them in sequence.
  12. You can join/edit clips in Camtasia Studio:
  13. Yeah, but I still have to watch each and every clip.
    Jul 2006
    Mexico
    i tried many programs. all sucked so far. then i found one that works awesome. heres the site:
    http://www.adshareit.com/
