Hi i was wondering hot to upload subtitles.I have some Divx movies and would like to watch them with subtitles.2 avi files and to parts of subtitles for each movie.thx
Burn all the files to a single disc as a data DVD. (I use Record Now). If the subtitle folders are in a format compatible with the Philips it will play them when you select subtitles from the remote handset.
You mean 5960?
Just put them on the disk with the right short name:
film.avi
film.srt -
I got the subtitles with txt ending and the dvd does not read them
.Anyway i can change the format to "srt"??
Take a look in our Subtitles Forum, especially the 'Stickys' at the top of the forum. Probably this one for starts: https://forum.videohelp.com/viewtopic.php?t=267416
Philips DVP5960 and USB
By lets in forum DVD & Blu-ray PlayersReplies: 715Last Post: 10th Jun 2012, 11:03 -
philips dvp5960
By tonie in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Sep 2008, 15:58 -
Philips DVP5960 or 5982?
By siskiou in forum DVD & Blu-ray PlayersReplies: 11Last Post: 20th Apr 2008, 22:28 -
Philips DVP5960 or DVP5980 and TXT subtitles
By Babers in forum DVD & Blu-ray PlayersReplies: 7Last Post: 10th Oct 2007, 13:46 -
Philips DVP5960 Help
By clubfoot in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Sep 2007, 06:39
