Greetings to the Forum,
I've been lurking here for almost a year and whatever successes I've had in the video arena are due in large part to all the participants here, particularly Lord Smurf.
Per his recommendations at digitalFAQ, I set my old AIW on my old machine to capture analog VHS to 352X480 with great success. When I built my new machine I used the same settings with the new AIW 2006. It's worked fine for about a month, but for some reason in the past few days, it's doubling the width to 960. I've been playing with the settings and doing tests for the better part of today and checking the results with gspot, and it's always the same. Finally I edited my capture settings to 352X240. When I check the resulting file with gspot, it comes back at 352X480.
Anybody have any thoughts as to where I should look in the settings to avoid this issue. Damned if I can find it, either in ATI MMC or in the Catalyst "control center". Maybe I should mention that I have a 19" wide-screen monitor. I have "Aspect Ratio" set to "Auto". Should also mention that this issue crops up whether I'm recording from the tuner or the line in.
Any help would be greatly appreciated.
Results 1 to 1 of 1
ATI AIW 2006 PCIE -- do I need the breakout box?
By robjv1 in forum Capturing and VCRReplies: 8Last Post: 29th Jul 2011, 09:44 -
My TV Caps have Low Audio Volume and Hiss - ATI AIW 2006 PCIE
By somebodeez in forum Capturing and VCRReplies: 16Last Post: 26th Apr 2008, 07:08 -
Problems with Pal-60 capture using ATI AIW 2006 PCI express Radion X1300
By DB83 in forum Capturing and VCRReplies: 2Last Post: 6th Aug 2007, 16:49 -
Anyone know if the ATI All in Wonder 2006 Edition can capture PAL 60?
By MarksmanR in forum Capturing and VCRReplies: 5Last Post: 29th Jul 2007, 07:10 -
Ati AIW won't remember video resolution
By crimzind in forum Newbie / General discussionsReplies: 1Last Post: 9th Jul 2007, 16:07
