Can ffmpegX convert AVIs, etc so they're compatible with the new AppleTV? If so, what would be the conversion settings in ffmpegX?
I'm running some tests right now exporting from QuickTime Player Pro to the new AppleTV setting. When done, I'll post the specs; perhaps it's not much more than enhanced resolution (potential) and bitrate.
It's an interesting question and one, I'm sure, on which Major is working; no flies on that guy.
Just for grins (as I don't have an AppleTV) I exported a short segment from iMovie using the "AppleTV" option (in the Expert section). Here are the specs from the result:
Bit Rate: 1.45 Mbps
Video Tracks:
H.264, 720 × 480, ~21.782 fps, 1.32 Mbps
Audio Tracks:
MPEG-4 Audio stereo, 44.1 kHz, 128 kbps
Kind of funny-looking, eh? As I indicated above, this was from a 4:3 iMovie project (NTSC) yet it's apparent that QT left the 720 pixel width alone even though the project would export to iPod as 640x480. One might wonder whether the AppleTV will "pillar-box" the result automatically or play it, distorted, at 720w.
I realize this post doesn't answer all of the questions (and I invite anyone with an AppleTV to contribute) but I'd like to see this thread stay active.
Yeah anything encoded for the iPod will definitely work. The max setting for screen sizes and bitrate are available on apple.com. You should basically be able to retain all the quality of xvid or divx video, even 720p Xvids using H.264. The only question yet to be answered would be what profile level the AppleTV supports.
I just done a MP4 H.264
Mencoder H264, 720x576,
1214 Kbps, 25 fps, no crop
How can i make it with 5.1 sound
Under Audio i selected (channels: 5:1)
But when i playback the file i quicktime - it says stereo ?
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
ffmpegX produces non-fuctional files or no files
By sloopy in forum ffmpegX general discussionReplies: 5Last Post: 5th Nov 2008, 00:35 -
mkv to appletv on linux
By wiz561 in forum Newbie / General discussionsReplies: 0Last Post: 6th Oct 2008, 20:25 -
Converting AVI files to Video_TS files/ffmpegx V0.0.9Y OS is Tiger.
By sadepussycat in forum MacReplies: 10Last Post: 2nd Jun 2008, 15:43 -
Help! Converting to AppleTV
By DiGNAN17 in forum Video ConversionReplies: 4Last Post: 23rd Dec 2007, 11:21
