Hi everyone,
I'm trying to figure out how to burn a 1080i file onto an 8.5GB disc. As is I have 3 seperate clips, 2 of which are rather large (around 4.5GB) and the other a smaller one around 1 GB. My first thought was to just cross my fingers and hope Nero can deal with it. Since all files are ".ts" I just thought I could use Nero Vision 4 and throw them on a DVD. But when I do it says that my 1080i file has is only 720x480. I don't know much about hd burning but that doesn't seem right. I would prefer not to waste the DL DVD disc as they aren't cheap. What is the easiest way to ensure HD quality? How should I go about burning my video clips? Any suggestions, direction or help would be greatly appreciated. Thanks!
You can't burn as dvd-video if you want hd quality. I would just burn as data and get a dvd player / htpc that reads ts files.
Burn your two large approx. 4.5 GB files (they better not be bigger than this or it won't work) to separate DVD discs and burn the small file to a 3rd DVD disc. I did something like this last year with some World Cup recordings I made. Maybe in another year or two or three I'll be able to make a proper DVD in some high def format with them. The capacity of dual layer discs is really about 8.5 GB, so you're not going to be able to fit all your video on one dual layer disc. Yes, that's right, one dual layer disc is smaller than 2 single layer DVDs. Burn your files as data discs and do NOT let Nero convert them to DVD. Use Nero Express or Nero Burning ROM and do NOT use Nero Vision!
well thats disappointing... ah well I will try your way jman and see what happens. If only blu-ray burners didn't cost 1000 bucks
BTW Bladrick what is htpc? hd something for pc?
Home Theatre PC.
About your question if you want HD content on DVD you need to find software which would author and burn such a disc. And this is not all - you need to playback it as such.
Camcorder: buy 1080i or 1080p? Final Cut Express only does 1080i
By adrien23 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 12th Nov 2010, 06:37 -
1080i to Standard DVD
By noisymonk in forum EditingReplies: 4Last Post: 3rd Jun 2010, 18:03 -
Viewing and Burning 1080i DD5.1-CtrlHD.ts.par2 files
By Sharkman in forum Newbie / General discussionsReplies: 7Last Post: 26th Apr 2008, 14:07 -
Is 1080i thru Component the same video quality as 1080i thru HDMI?
By Denvers Dawgs in forum DVB / IPTVReplies: 27Last Post: 13th Jul 2007, 17:25 -
1080i .ts or .mpg to DVD help
By delpis in forum Authoring (DVD)Replies: 4Last Post: 8th Jun 2007, 20:49
