Quick question for the FCP gurus here...
I have about 3 different monitor setups that I use depending on where I am, my laptop only, my laptop and widescreen monitor, and my laptop and standard monitor. Each one has a different layout saved, however its somewhat of a pain.
I was just curious, is there anyway for FCP to automatically load the specific layout depending on which monitor is plugged in? The reason I ask is that I notice that depending on what monitor is loaded the choices in my layouts menu is changed accordingly, so it doesn't seem unreasonable for it to detect the monitor and then change layout accordingly.
thanks to anyone who could help!
:: ehmjay.
the problem is that FCP uses the last monitor layout you chose
to save to it's preferences, so that the next time you start FCP,
it automatically chooses that layout by default.
So to answer your question, you would need to save different
FCP prefs, each with the monitor layout of your choice,
as your default choice,
and then switch the prefs out Before launching FCP.
so in a sense you would have a folder on the desktop
labeled:
FCP Prefs
and then have three sub-folders:
laptop
laptop wide
laptop stand
and in each of these would be the same files:
Final Cut Pro x.x Preferences
Final Cut Pro Obj Cache
Final Cut Pro Pref Cache
but each would corrospond to the layout named on the sub-folder.
An Automator script app could be written to find these files,
and then replace them with (copies of) your choices.
You would write three seperate Automator apps,
save them to your desktop,
and then run the app of your choice BEFORE launching FCP
and then the default layout would be automatically changed
for you."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
No audio in MPC depending on the player exe file name
By mebs in forum Software PlayingReplies: 7Last Post: 27th Sep 2010, 03:06 -
Auto-load subtitles from a Blu ray Disc
By jimhoofd in forum SubtitleReplies: 4Last Post: 9th May 2010, 17:25 -
Different ending for main content, depending on language possible?
By doctorjellybean in forum Authoring (DVD)Replies: 3Last Post: 2nd Nov 2009, 21:17 -
Using AVDC 300 to monitor pal out of FCP. Problems?
By rovdog in forum Capturing and VCRReplies: 0Last Post: 12th Aug 2009, 20:02 -
FCP: What is the best way to work with .m2v files in a FCP timeline?
By murraymile in forum MacReplies: 1Last Post: 23rd Jan 2009, 16:59
