Hello,
I want to import some scenes from a miniDVD[shot with Sony camera]. Can I import vob files directly in Premier Pro 2[audio+video] or do I have to encode vob files into eg. avi files?Do I have to deinterlace the scenes?How?
Thenx very much...
Have you tried to import a VOB? If you can't, you'll have to use one of the many frameservers available. If you get the VFAPI plug-in, you can use DVD2AVI or Virtualdub to frameserve the VOB. Once imported, you don't need the VOB anymore. Check out the tools and many guide available here.
get MPEGstreamclip, use it to convert your DVD footage into DV AVI files, work with them from there. That's what we do and I work for a studio.
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 17:25 -
Adobe Premier Elements 4 templates - can I import a single one
By jlbvt in forum Authoring (DVD)Replies: 0Last Post: 7th Mar 2011, 10:53 -
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 14:50 -
Premier Pro Video Import Problem
By JojoTilly in forum Video ConversionReplies: 0Last Post: 3rd Jun 2008, 18:42 -
Using maya 8.5 with premier pro
By vipertongn in forum EditingReplies: 5Last Post: 8th Jul 2007, 04:29
