When I attempt to convert an Mpeg4/AVI file to a MOV file, all seems to go well except: I do not end up with a saved/new MOV file.
The log also shows an "Incorrect frame rate" statement
The Player does play the Mpeg4 file I am trying to convert.
Any suggestions?
Thanks in advance.
Typical Log file follows:
Encoding started on Sat Mar 24 10:25:39 MST 2007
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
configuration: --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-pthreads --enable-x264
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
built on Apr 15 2006 08:41:02, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
Input #0, avi, from '/Users/noah/Desktop/Savannah Video 0207/200MOVIE/CLIP0062.AVI':
Duration: 00:00:09.5, start: 0.000000, bitrate: 1849 kb/s
Stream #0.0, 30.00 fps(r): Video: mpeg4, yuv420p, 640x480
Stream #0.1: Audio: mp2, 44100 Hz, stereo, 64 kb/s
Results 1 to 1 of 1
Error when saving from VirtualDub as AVI with compression
By Thread7 in forum Newbie / General discussionsReplies: 5Last Post: 9th Aug 2010, 22:41 -
Not Saving the File anywhere
By MrBoiler in forum ffmpegX general discussionReplies: 8Last Post: 31st Jan 2010, 08:17 -
Saving dvd recorder hard disk videos says error
By xmanhattan in forum DVD & Blu-ray RecordersReplies: 4Last Post: 14th May 2009, 13:16 -
Adding a text logo to a video file without re-saving it to another file?
By coxanhvn in forum EditingReplies: 4Last Post: 19th Dec 2008, 16:03 -
VirtualDub error while saving with subtitle on
By ajumma in forum SubtitleReplies: 0Last Post: 3rd Jun 2007, 02:35
