Hi, Im trying to burn a 700MB divx file to a 4.5GB dvd-r on nero 7 however, it says that the size of the video file exceeds the space available it takes up around 4.6GB, this is a reoccuring problem with several other files.
thanks
Burn it as data. If you want a Video DVD, you need to convert divx to MPeg2.
https://www.videohelp.com/dvdRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Yes, burn as data. And the reason 700 MB is a common size is that it fits on a CDR, which is a bit cheaper than a DVD if you're only putting one file on a disc.
That's 'cause you're using a template from the Nero Smartstart menu. Is Recode part of your Nero package? Click on the button on the left of the Smartstart menu and expand the menu to show the tools. Select Nerovision, in the menu click make DVD, click DVD-video, import files. Edit and add chapters, create a menu... When you get to the burn page, change the target to folder on your Hard Drive, make a new folder and pick it, click burn. If you didn't get Recode with Nero, download DVDShrink. Using one of those, import the DVD you just created and it will fit on a disc now. Make sure to go through the options for Shrink and enable the quality settings. In Recode, just check the two boxes at the bottom of the burn page.
how to convert and save audio & video files? how large of a HD?
By speone in forum Newbie / General discussionsReplies: 2Last Post: 15th Feb 2012, 14:55 -
Play severhigh resolution large video files from a playlist (for a concert)
By American yeah in forum Software PlayingReplies: 1Last Post: 29th Sep 2011, 08:25 -
What to do with large AVI video files taken on my digital camera?
By scormodo in forum Newbie / General discussionsReplies: 9Last Post: 30th Aug 2009, 12:13 -
DVD player can't read large DIVX files
By Alistair George in forum Authoring (DVD)Replies: 14Last Post: 27th Jan 2009, 19:16 -
video files are to large!!!!!!!!!!
By sharmine in forum Newbie / General discussionsReplies: 3Last Post: 5th Jan 2008, 07:30
