Hi There,
My camera (Sony HC96) doesn't support creating fade in/fade out effect conveniently during recording, so I'd like to apply this effect to my dv avi files.
Is there any tool that's capable of adding fade in/fade out by batch processing all avi files in specific folder - it would also be nice having this done with smart rendering.
Thanks for your help!
I also got the hc96 - you can create this effect and others with the cam. But its better to do this with a program.
I can imagine that virtualdub can do this job.www.hc96.de -> All about the Sony DCR-HC96 and Camcorder accessories. -
If you are still in DV format, you still have a frame by frame representation of your video so each frame can be edited with transitions or filters without affecting other frames. Prosumer editors support batch processing and "smart rendering" , consumer programs usually don't.Originally Posted by bmf
Even if DV is recoded, the losses are small compared to MPeg. PAL DV (4:2:0) is less tolerant for multigeneration than NTSC DV (4:1:1) since CbCr get reinterpolated in each pass.
I can't think of a program that does exactly what you want, but it would be easy to write one. Many consumer programs can be set for auto transitions on the timeline but not for batch processing clips.
If you were to write a program, "fade-in" "fade-out" should be done in Y or Alpha for minimal damage. Conversion to RGB should be unnecessary.
avisynth - how to fade in (but audio has to fade in faster)
By adom in forum EditingReplies: 13Last Post: 31st Jan 2011, 13:45 -
Fade in Fade Out CD Music Software
By mn072065 in forum ComputerReplies: 0Last Post: 6th May 2008, 09:23 -
Fade in Transition Fade out scenes
By ancient in forum Authoring (DVD)Replies: 4Last Post: 30th Nov 2007, 06:04 -
how can I add "Fade in / Fade out" effect in my video clips
By mb508 in forum EditingReplies: 5Last Post: 9th Jul 2007, 17:02 -
Fade-in\Fade-out filter, VirtualDub MOD
By GangstaRap in forum Video ConversionReplies: 3Last Post: 21st May 2007, 21:58
