  1. Member PTsniper's Avatar
    Aug 2006
    Portugal
    Hello everyone!
    I'm having a big problem with DVD Lab Pro (all versions) probably I'm doing something wrong, but I don't know what.
    This is my problem: normally I could import vobs and the I would demx or demltiplkex them. But now, when I try to do that DVD Lab Pro gives me an error that says this:
    but I can keep my work until the end without demultiplexing the videos, but whe I want to compile my DVD it shows me this error:
    and when I press "Proceed" the 1st error comes again.
    And I'm getting desperate.
    Any clues to help me?
    Thanks in advance.
    P.S. Casually it also appears an error saying that it coulkdn't open the Vob.
    Apr 2004
    Miskatonic U
    Try demuxing with PGCDemux or Rejig, then importing the elementary streams into DLP instead.
    How were they ripped in the first place ?
    Read my blog here.
  3. Member PTsniper's Avatar
    Aug 2006
    Portugal
    They were not ripped, they were converted with ConvertXtoDVD
  4. Member PTsniper's Avatar
    Aug 2006
    Portugal
    Thank You so much man,
    the DVD is now compiled and working perfectly.
    Edit --» P.S. I used PGCDemux.
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    I haven't used the demuxer in DLP since about version 1.5. Not because it didn't work, but because I either encode to elementary streams in the first place, or demux before authoring. It could also be something not quite right in the output from ConvertXtoDVD. DLP canbe picky, so if something is a little off, it might choke.
    Read my blog here.
  6. Member PTsniper's Avatar
    Aug 2006
    Portugal
    That was probably the problem, but now it's working great.
    Thanks to you .
