im trying to author some dvdr (the pursuit of happyness)
and when i demux the files i get 2 audio streams
both english but one is stereo and one is AC3.
how can i keep both of them (im using the muxman tutorial),
my goal is that i can choose on my dvd remote control
if i want ac3 or stereo sound.
do i need to put the stereto audio stream on AUDIO2 on muxman?
thanks.
well, the thing is that this movie is all talking no effects,
so on AC3 sound i must turn the volume really high.
and what do you mean by "downmix itself"? -
DVD players will downmix 5.1 to stereo if configured to output through standard stereo analogue PCM output. You will only get 5.1 if you use a digital connection to your amp, or 6 separate analogue outputs. Similarly, software players that do not have a 5.1 card will output stereo. It is part of the basic DVD specification.
Read my blog here.
I see now, thanks a bunch for your help,
I do have one last question though,
You wrote "use the space for your video", what do you mean by that?
when i remux all my streams i can higher up the bitrate of the video stream?
cause from what i know, its constant already. -
I assume this is a dual layer original.What he means is,trying to put 2 layers of material onto a single layer disc requires some crunching of video to do so.The more extra stuff you get rid of leaves more room for the main movie,hence better quality video.I'll bet the stereo audio is commentary.Get rid of it and all the trailers and subtitles etc.
bmiller,ont.canada
Are there any tutorials to convert stereo MP3 to stereo AC3?
By rocky12 in forum AudioReplies: 10Last Post: 4th Sep 2011, 20:05 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 20:16 -
ac3 5.1 to aac stereo 2.0
By miss in forum AudioReplies: 4Last Post: 12th Dec 2009, 00:34 -
Karaoke DVD -> Chapters (2 audios) -> .mpeg (2 audios) ???
By webking1 in forum Newbie / General discussionsReplies: 3Last Post: 16th Feb 2009, 12:49 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23
