I have already opened the topic about this error-
it occasionally occures when you are extracting audio from .avi file with ffmpeggui.
You gave me advice to install AC3ACM codec and it worked, but now I got this error while this codec is installed. So what other codec besides AC3ACM should I install to resolve this error?
Properties of the file in question:
PlayTime : 2h 9mn
Width : 640
Height : 480
Aspect ratio : 4/3
Frame rate : 23.976 fps
Resolution : 8
Chroma : 4:2:0
Interlacement : Progressive
Writing library : Lavc51.1.0
Audio #0
Codec : MPEG-1/2 L3
Family : MPEG-1
Info : MPEG-1 or 2 layer 3
PlayTime : 18s 602ms
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44 KHz
For such stubborn audio in avi which give different errors in ffmpeggui and virtualdub I have used several times successfully QuEnc. Load the avi and in advanced settings set No Video select compression type (ac3 or mp2), Apply, Encode - ready
Actually QuEnc use the same encoding engine as ffmpeggui. Why it works in former and not work in latter I have no idea.
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 10:28 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 09:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 03:22 -
Point to point sharing with wifi adapter and wifi router?
By yoda313 in forum ComputerReplies: 5Last Post: 17th Jul 2008, 18:47 -
Photo enlargement & division for printing
By kippard in forum ComputerReplies: 7Last Post: 17th Sep 2007, 03:35
