Results 1 to 12 of 12
  1. my dvdx wont create my avs file for tmpgenc. i have installed and uninstalled, and installed servers trying to figure the problem out. after i create the avs in dvdx video server plug in, i go to tmpgenc and try to find it but its not there as a compressable file. what do i do to fix the problem.
    please help
    Feb 2001
    Berlin, Germany
    Select file type: all files.
  3. i did and it tells me this is an unsupported file
  4. i tried to select all types and it tells me that its an unsupported file. what is the main parts i should have that make avs work right? what is the main plug in or file?
    Feb 2001
    Berlin, Germany
    I don't use DVDx, but if you want to load a .avs into TMPG it is usefull to disable the "directshow multimedia file reader" box under options > enviromental settings > VFAPI plugin.
    If this does not help, please post the entire error message. Also play the .avs with Windows media player and see whether it gives you an error message as well.
  6. now it says "unable to connect to frame server down?" bt the whole error before was that " cannot support, un supported file"
  7. i just tried it again and it crashed, i selected all files and picked to avs and it froze.
    Feb 2001
    Berlin, Germany
    Well, as mentioned I do not work with DVDx. Since many people seem to have problems with the video server plugin setup I decided to have some tests myself. I am still downloading it. Meanwhile have a look at this guide:
    http://www.labdv.com/en/manuals/dvdx_guide.php
    Feb 2001
    Kalmar, Sweden
    .avs files are frameservers for "Avisynth", get it at http://www.videotools.net
    The .avs files are scripts that Avisynth uses...
    Magnus Jensen
    A.K.A Geezus
  10. Look Avsynth s not very compatible ..so i suggest you use the AviWrapper codec that Video Server v0.93 includes and it make and avi file which can be used on most encoders...i have made a guide for it and i have sent it to Baldrick...sorry i dont know when is going to put it up...but yo can ask by PMing him
  11. doesnt that cause a huge avi to be put on my computer. with avs you get around that right?
  12. wrong the Avi file is a fake av file the that does that same job as avc files but more compatible and the files size in only like 3mbs and if that too large for you..too bad
