Good day all.
I've been capturing some VHS video to my hard drive through a Hauppauge PVR-350. I captured and edited in 12,000 bps. The video looked great.
When I went to author with GUIforDVDAuthor, the program kicked me an error saying that "too many frames were being dropped."
Do I need to reencode to a lower bitrate before I author? What procedure would you recommend?
Thanks in advance.
From 'WHAT IS' DVD to the upper left on this page:
That may be your problem. If so, then you would need to re-encode to a lower bitrate. You can use a bitrate calculator (Available in 'Tools') to select the proper bitrate to fill your DVD disc. Then re-encode your video to the lower bitrate. You probably don't need to re-encode the audio if it is already in a DVD compliant format, just allow for the size of it when you set your bitrate in your encoder. And allow about 100 - 200 MB for authoring. If you need a encoder, there are freeware ones available, also in 'Tools'.Total bitrate including video, audio and subs can be max 10.08 Mbps (10080 kbps) -
You might try another program such as TDA or Ulead VideoStudio.I recommend using a max video bitrate of 8Mbps to capture.
Thanks guys.
I think I'll just recapture at 8,000 bps and do the authoring again. I can't seem to figure out how to set the PVR 350 capture rate at 9000, which is what I'd really like.
I'm still trying to get this thing right.
I really apprecaite the help. -
https://forum.videohelp.com/viewtopic.php?p=1677646#1677646Originally Posted by dadrab
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Is the bitrate high enough?
By Weef in forum DVD RippingReplies: 23Last Post: 25th Jun 2009, 10:29 -
Caching files with high bitrate?
By therock003 in forum Software PlayingReplies: 5Last Post: 15th Dec 2008, 17:54 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54 -
High Bitrate Flash FLV
By Soopafresh in forum Video ConversionReplies: 1Last Post: 24th Nov 2007, 04:04
