I have Nero OEM. (version 6 I think)
I used to be able to burn video CDs and now I can't.
I accidentally deleted it off my computer because I thought I would just download Nero 7. (I didn't know you had to pay for it)
So, I finally managed to find my Nero CD and reinstalled it.
Now it goes for about 5 minutes before I see
"error during encoding."![]()
Here's the log in its entirety: error in bold (same error every time)
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 7/22/2004 4:33:44 PM
Nero version: 6.3.1.26 (Nero Express)
Recorder: <LITE-ON CD-RW SOHR-5239S>Version: 2S05 - HA 1 TA 1 - 6.3.1.26
Adapter driver: <atapi> HA 1
Drive buffer : 1536kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <SAMSUNG CD-ROM SH-152A >Version: C503 - HA 1 TA 0 - 6.3.1.26
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SP0411N atapi Port 0 ID 0 DMA: On
CdRomPeripheral : SAMSUNG CD-ROM SH-152A atapi Port 1 ID 0 DMA: Off
CdRomPeripheral : LITE-ON CD-RW SOHR-5239S atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
SAMSUNG CD-ROM SH-152A D: CDRom0
LITE-ON CD-RW SOHR-5239S E: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 66060288 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 447MB (458224kB)
Free physical memory: 134MB (137380kB)
Memory in use : 70 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
23.3.2007
Video CD
1:13:13 PM #1 Text 0 File VCDDoc.cpp, Line 1481
VideoCD document burn settings
Compilation type : VCD
Menu : Disable
Picture in separate folder : TRUE
Folder name :PICTURES
Use CD-I : TRUE
CD-I configuration : CONTROLS=ALL
CURCOL=YELLOW
PSDCURCOL=RED
PSDCURSHAPE=ARROW
CENTRTRACK=2
AUTOPLAY=AUTO_ON
DUALCHAN=DUAL_ON
TIMECODE_X=64
TIMECODE_Y=100
LOTID_X=64
LOTID_Y=64
ALBUM=STANDARD
Encoding bitrate mode : User defined (kb/s)
1:13:13 PM #2 Phase 82 File dlgbrnst.cpp, Line 1855
Encoding video
1:13:13 PM #3 Text 0 File VCDCompilationImpl.cpp, Line 490
Using Nero Video Converter version 0.00
1:13:13 PM #4 Text 0 File AVIVCDFileItem.cpp, Line 879
Encoding C:\Documents and Settings\Owner\My Documents\FLV Vids\LotR PotC Music Vid DVD\tiger_0002.wmv to C:\DOCUME~1\Owner\LOCALS~1\Temp\NER808.tmp
ScalingType: 0 Video: yes Audio: yes
File size: 10357641 bytes
Resolution: 320x240 30 Hz
Frames: 7207
1:13:13 PM #5 Text 0 File AVIVCDFileItem.cpp, Line 892
Playing time: 240.226667 s
Requested rate: 225 KB/s
iVideoRate=0
iAudioRate=32
Estimated size: 18017 blocks
1:16:13 PM #6 Text 0 File AVIVCDFileItem.cpp, Line 921
Encoding done
1:16:14 PM #7 Text 0 File VCDFileItem.cpp, Line 367
Actual size: 18041 blocks
1:16:14 PM #8 Text 0 File VCDFileItem.cpp, Line 371
The generated Video file is 0.999668 of the evaluated size
1:16:14 PM #9 Text 0 File AVIVCDFileItem.cpp, Line 879
Encoding C:\Documents and Settings\Owner\My Documents\FLV Vids\LotR PotC Music Vid DVD\wiz.wmv to C:\DOCUME~1\Owner\LOCALS~1\Temp\NER80B.tmp
File size: 2563325 bytes
Frames: 2040
1:16:14 PM #10 Text 0 File AVIVCDFileItem.cpp, Line 892
Playing time: 67.986667 s
iVideoRate=0
iAudioRate=32
Estimated size: 5099 blocks
1:17:04 PM #11 Text 0 File AVIVCDFileItem.cpp, Line 921
Encoding done
1:17:05 PM #12 Text 0 File VCDFileItem.cpp, Line 367
Actual size: 5125 blocks
1:17:05 PM #13 Text 0 File VCDFileItem.cpp, Line 371
The generated Video file is 0.999220 of the evaluated size
1:17:05 PM #14 Text 0 File AVIVCDFileItem.cpp, Line 879
Encoding C:\Documents and Settings\Owner\My Documents\FLV Vids\LotR PotC Music Vid DVD\meolympics2.wmv to C:\DOCUME~1\Owner\LOCALS~1\Temp\NER80E.tmp
File size: 3645085 bytes
Frames: 3037
1:17:05 PM #15 Text 0 File AVIVCDFileItem.cpp, Line 892
Playing time: 101.226667 s
iVideoRate=0
iAudioRate=32
Estimated size: 7592 blocks
1:18:19 PM #16 Text 0 File AVIVCDFileItem.cpp, Line 921
Encoding done
1:18:19 PM #17 Text 0 File VCDFileItem.cpp, Line 367
Actual size: 7616 blocks
1:18:19 PM #18 Text 0 File VCDFileItem.cpp, Line 371
The generated Video file is 0.999213 of the evaluated size
1:18:19 PM #19 Text 0 File AVIVCDFileItem.cpp, Line 879
Encoding C:\Documents and Settings\Owner\My Documents\FLV Vids\LotR PotC Music Vid DVD\chumba.wmv to C:\DOCUME~1\Owner\LOCALS~1\Temp\NER811.tmp
File size: 4334665 bytes
Frames: 7006
1:18:19 PM #20 Text 0 File AVIVCDFileItem.cpp, Line 892
Playing time: 233.520000 s
iVideoRate=0
iAudioRate=32
Estimated size: 17514 blocks
1:20:54 PM #21 Text 0 File AVIVCDFileItem.cpp, Line 921
Encoding done
1:20:55 PM #22 Text 0 File VCDFileItem.cpp, Line 367
Actual size: 17537 blocks
1:20:55 PM #23 Text 0 File VCDFileItem.cpp, Line 371
The generated Video file is 0.999601 of the evaluated size
1:20:55 PM #24 Text 0 File AVIVCDFileItem.cpp, Line 879
Encoding C:\Documents and Settings\Owner\My Documents\FLV Vids\LotR PotC Music Vid DVD\rohanclub.wmv to C:\DOCUME~1\Owner\LOCALS~1\Temp\NER815.tmp
File size: 3101825 bytes
Frames: 2188
1:20:55 PM #25 Text 0 File AVIVCDFileItem.cpp, Line 892
Playing time: 72.920000 s
iVideoRate=0
iAudioRate=32
Estimated size: 5469 blocks
1:21:50 PM #26 Text 0 File AVIVCDFileItem.cpp, Line 921
Encoding done
1:21:50 PM #27 Text 0 File VCDFileItem.cpp, Line 367
Actual size: 5494 blocks
1:21:50 PM #28 Text 0 File VCDFileItem.cpp, Line 371
The generated Video file is 0.999091 of the evaluated size
1:21:50 PM #29 Text 0 File AVIVCDFileItem.cpp, Line 879
Encoding C:\Documents and Settings\Owner\My Documents\FLV Vids\LotR PotC Music Vid DVD\bohemrap.wmv to C:\DOCUME~1\Owner\LOCALS~1\Temp\NER818.tmp
File size: 15272355 bytes
Frames: 11185
1:21:50 PM #30 Text 0 File AVIVCDFileItem.cpp, Line 892
Playing time: 372.826667 s
iVideoRate=0
iAudioRate=32
Estimated size: 27962 blocks
1:26:32 PM #31 Text 0 File AVIVCDFileItem.cpp, Line 921
Encoding done
1:26:33 PM #32 Text 0 File VCDFileItem.cpp, Line 367
Actual size: 27990 blocks
1:26:33 PM #33 Text 0 File VCDFileItem.cpp, Line 371
The generated Video file is 0.999929 of the evaluated size
1:26:33 PM #34 Text 0 File AVIVCDFileItem.cpp, Line 879
Encoding C:\Documents and Settings\Owner\My Documents\FLV Vids\LotR PotC Music Vid DVD\rhymes.wmv to C:\DOCUME~1\Owner\LOCALS~1\Temp\NER81B.tmp
File size: 9671832 bytes
Resolution: 320x240 25 Hz
Frames: 5837
1:26:33 PM #35 Text 0 File AVIVCDFileItem.cpp, Line 892
Playing time: 233.480000 s
iVideoRate=0
iAudioRate=32
Estimated size: 17511 blocks
1:26:33 PM #36 Text 0 File AVIVCDFileItem.cpp, Line 921
Encoding done
1:26:33 PM #37 AVIVCDFILEITEM 10 File AVIVCDFileItem.cpp, Line 938
Error during encoding
1:26:33 PM #38 Text 0 File AVIVCDFileItem.cpp, Line 985
Temporary file C:\DOCUME~1\Owner\LOCALS~1\Temp\NER808.tmp deleted
1:26:33 PM #39 Text 0 File AVIVCDFileItem.cpp, Line 985
Temporary file C:\DOCUME~1\Owner\LOCALS~1\Temp\NER80B.tmp deleted
1:26:33 PM #40 Text 0 File AVIVCDFileItem.cpp, Line 985
Temporary file C:\DOCUME~1\Owner\LOCALS~1\Temp\NER80E.tmp deleted
1:26:33 PM #41 Text 0 File AVIVCDFileItem.cpp, Line 985
Temporary file C:\DOCUME~1\Owner\LOCALS~1\Temp\NER811.tmp deleted
1:26:33 PM #42 Text 0 File AVIVCDFileItem.cpp, Line 985
Temporary file C:\DOCUME~1\Owner\LOCALS~1\Temp\NER815.tmp deleted
1:26:33 PM #43 Text 0 File AVIVCDFileItem.cpp, Line 985
Temporary file C:\DOCUME~1\Owner\LOCALS~1\Temp\NER818.tmp deleted
1:26:33 PM #44 Text 0 File AVIVCDFileItem.cpp, Line 985
Temporary file C:\DOCUME~1\Owner\LOCALS~1\Temp\NER81B.tmp deleted
1:26:33 PM #45 Text 0 File VCDDoc.cpp, Line 2774
VCD options:
Create standard compliant CD: YES
Encoding resolution: NTSC
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 11/3/2005 4:00:00 AM
File 'Drivers\PXHELP20.SYS': Ver=3.00.11B, size=46080 bytes, created 11/3/2005 4:00:00 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 8/4/2004 8:00:00 AM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Results 1 to 10 of 10
What do you mean "deleted" it? Did you do an proper uninstall, or just dump the program folder?
Try uninstalling it through Add/Remove programs and then reinstall it from the disc. Make sure the disc is clean. If that doesn't do it, I would suspect the movie you are trying to recode is just corrupt. -
Even if you do a proper uninstall, there are still remnants of Nero left on your system and that may be causing your problem. You need to use Nero Clean Tool after you uninstall. http://www.nero.com/nero7/enu/Clean_Tools.html You should uninstall your OEM version too, and use the same program in the proper version.
Then reinstall your OEM and it may work.
BTW, Nero is not a very good encoder anyway, so you are not missing much. I would use a different encoder. If you are encoding to VCD or MPEG-1 format, TMPGEnc encoder is free for that and one of the best. For VCDs also, you might want to use VCD Easy for the authoring part.
And welcome to our forums.
Did that. I know it can burn DVDs, it burns small ones. Just a few minutes, but it won't burn much over twenty minutes. I've burnt one that was about an hour in length before.Originally Posted by redwudz
Nero is all I have. I only have it because that's what the computer people put on it when they accidentally deleted my old program off when they wiped my hard drive. *Hurray virus*
I didn't know that's what they put on at first. I just know that I popped in a CD to burn one day and Nero popped up. (which is why I didn't know you had to pay).
Anyhow, I've gone to add/remove files as well and I've used clean tools. -
Your computer details say you have a 2 gb hard drive. I had a coworker who literally ran out of hd space when ripping movies and even when he had 'enough' it still caused buffer underrun errors burning because the drive was still too full to defragment.
Can you repost better computer details in your profile? -
Ah, memory could be the problem. I don't know how to get the other details. What do you need to know and how do I find it out?Originally Posted by dnix71
For your CPU and memory info, 'Start>Control Panel>System:
For hard drive, right click on your boot drive icon>Properties:
This is from my laptop. -
CPU:
AMD Athlon(tm) XP 2200+
1.82 GHz, 448MB of RAM
Hard drive:
capacity - 37.2GB
free - 2.36GB -
Your memory amount looks fine. You probably have 512MB RAM with some used by the on-board video. But you are low for hard drive space. There is enough there for a CD, but a DVD file would run you out.
This may be the cause of your errors, depending on how much space your program needs for the encoding, etc.
I like to keep about 1/4 to 1/3 of my total hard drive space unused. When you get too low on free space, Windows has to juggle files around and you end up with a lot of fragmentation. Windows also uses the hard drive for virtual memory space. You might consider clearing out about 5 - 8GB from your hard drive by deleting unnecessary files and emptying the temp files for Internet explorer.
The best option is probably to add another internal hard drive, assuming you don't have a laptop. If so, a external drive would work. -
I figured that was part of what was wrong with it. I'm having memory put into it when I get the chance.
Thanks for the help.
OEM versions of certain software
By turk690 in forum ComputerReplies: 1Last Post: 2nd Dec 2010, 19:19 -
Retail vs OEM
By bryankendall in forum ComputerReplies: 5Last Post: 3rd Dec 2009, 11:32 -
Error Nero AAC - no HC
By albo23 in forum Video ConversionReplies: 1Last Post: 17th Aug 2008, 14:06 -
NERO burn error
By Budokhan in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 20:58 -
Help. Nero error log
By R!ffraff in forum Newbie / General discussionsReplies: 7Last Post: 3rd Mar 2008, 15:22
