I'm following this tutorial:
https://forum.videohelp.com/viewtopic.php?t=275603
but instead of using Muxman im using IFOEdit since i need more than 8 subtitles..
but the problem is that on my computer everything seems fine
but when i play the finished dvd on my dvd player (apex 815) it doesn't
show any subtitle..
when i use muxman everything works.
can anyone help me doing this method but with IFOEdit?
Thanks in advanced.
Results 1 to 11 of 11
by subtitles i mean my hebrew text translation,
same as for english and french that are on that movie. -
well the problem is that i have the band of brothers dvd
and i want to add the hewbrew in the right place where it was originaly
that is in like place 16 so thats why i need more than 8 subs option. -
AFAIK you can also use more than 8 subtitles streams with muxman free version, but you have to save the project and edit the mxp file yourself. It is not a limitation of muxman as 'authoring engine', but only of the muxman gui.
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
I never knew that, although I have altered the mxp file before, but not for audio or subs. I just did a quick test with 10 subs and it seems to work on the authored vobs. Thanks for the info. It's worth a try on your part shay86.Originally Posted by borax
can u explain me how to author the mpx file myself?
do i need a special software for that? -
You only need a text editor (even notepad is suitable).
I haven't tried such many subtitles myself (I never had more than 3...), but I have often edited the mxp files (i.e. during the GfD -> 'GfM' development).
Try it like this:
Open MuxMan like 'normal'. Add your 8 possible subtitles.
Save the project (File -> Save Project)
Open the project file with a text editor.
Scroll down to the section where the subtitles are defined:
Now copy the part:Code:Item=Sub-Picture Stream { Stream Number=1 ... Item=Sub-Picture Stream { Stream Number=8 Language=en Language Extension=1 Display Mode=unspecified File=X:\Subs\TestSUP8.sup }
as often as necessary and add a 1 to the stream number each time (and change the sup filename and language of cause).Code:Item=Sub-Picture Stream { Stream Number=8 Language=en Language Extension=1 Display Mode=unspecified File=X:\Subs\TestSUP8.sup }
like:
Save the mxp file.Code:Item=Sub-Picture Stream { Stream Number=9 Language=la Language Extension=1 Display Mode=unspecified File=X:\Subs\TestSUP9.sup }
Open MuxMan like 'normal' and open the edited mxp file with File->Load project.
Just click on Start.
I just made a small test with 10 subtitles (same sup file for each, just using another language)=> No problem.GUI for dvdauthor:
I'll test that later on with my band of brothers dvd,
Thanks a lot mate for your help, Cheers
Audio/video/subtitle sync problem converting MKV to DVD (Muxman issue?)
By crackerbear in forum Authoring (DVD)Replies: 3Last Post: 7th May 2010, 12:23 -
Problem with Muxman and PAL DVD's...
By tomfoster in forum Authoring (DVD)Replies: 5Last Post: 9th Aug 2009, 05:51 -
Which dvd authoring software should I use? IFOEdit keeps crashing.
By architectofpain in forum Authoring (DVD)Replies: 4Last Post: 4th Aug 2009, 06:54 -
Problem when using muxman to author DVD
By ihmcjacky in forum Authoring (DVD)Replies: 17Last Post: 27th Sep 2008, 04:03 -
Encoding/AUTHORING short film to DVD (w/ CCE and IFOedit)
By sunsetblvd in forum Authoring (DVD)Replies: 13Last Post: 8th Aug 2007, 16:37
