I seem to be having a problem with TMPGEnc2.5 (maybe other versions aswell, gonna test tonight)
So far, using it, i have successfully managed to make VCD from DVD and everything went fine with the encoding. (using DVD2AVI method)
I have also done 1 movie at SVCD no problems.
I am now trying to encode my second movie in SVCD and TMPGEnc always seems to stop (not in the same place) and the report gives me an error something like "read error" or something.....I dont think its the .vob or the DVD2AVI output because it doesnt happen all in the same place.
Any ideas on what could be causing this?
Also, it seems that on every video i have done (apart from the VCD) there is a very slight audio sync problem (audio before video)....it is very slight but enough to put you off. Is there any way to combat this before the encode? What is the audio gap setting in the source filter?
If i have to de-multiplex/re-multiplex, then i might aswell try and get CCE working.
Thanks for any info.
Results 1 to 1 of 1
Problem With TMPGEnc
By Halibut72 in forum Video ConversionReplies: 2Last Post: 1st Oct 2008, 11:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 14:38 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 15:46 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 17:56
