Probably this is a dumb question, but I need to join several audio files.
I have audacity and its reported to be a good audio joiner.
So far I couldnt find a way to do it.![]()
Can someone please inform how to join 2 or more audio files with audacity ??
tks for yr help.
Open Audacity, play audio tracks in your media player,and record,pause or stop after ea, track and record tracks wanting to join, then save as wave or edit and save as MP3's..
at least thats how I've done it... may be other ways..
You could also play complete audio cd,record it all and cut/edit out tracks not needed or desired, using the slider I beam cursor by putting at end of selection then drag left to starting point. takes
a little effort and time but really nice program IMO!!
Hope that makes sense....good luck!
" Who needs Google, my wife knows everything" -
well, thanks for yr sugestion..
In fact that's a simple way to do it, but I thought there might be other possibilities.
will try that way. -
Open Audacity and open the first audio file. Then go to File/Import/Audio and import the second file. Click on the lower track(s) and select the entire track (can do Edit/Select/All), then Edit/Copy. Then click on the end of the upper track(s) and click Edit/Paste. Delete the lower tracks then Export As selected type.
Edit: Actually it's been a while since I've done this. Select All might not work as it might select all channels, but you can click on the tracks and select what you want to copy with the mouse."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
If you think that's a simple way to do it then try it!!!!
Like gadgetguy, it's been a while for me as well!!!!
regards....." Who needs Google, my wife knows everything"
Why does Audacity always save audio files differently?
By sldvd in forum AudioReplies: 15Last Post: 22nd Nov 2010, 15:17 -
How to join 2 avi files into one? together with Audio with avisynth + megui
By squall0833 in forum EditingReplies: 7Last Post: 11th Jul 2010, 10:47 -
How to join AVI files with multiple audio streams
By V@no in forum Newbie / General discussionsReplies: 2Last Post: 29th May 2010, 23:17 -
Question about using Audacity to join mp3 files
By jimdagys in forum AudioReplies: 2Last Post: 25th Dec 2008, 08:21 -
Join 2 uncompressed wav audio files
By kidcash in forum AudioReplies: 13Last Post: 11th May 2008, 03:15
