Im basically looking for the best dvd player that can play anything, and where you can plug a external hd on and watch from there too. I would like to have one thta could play avi/divx off a cd-r.. if thats possible? i would also like it to be under $120 because im poor. thanks in advance!!
Results 1 to 25 of 25
It appears you are asking about a standalone player. Then this would be better in our DVD Player forum. Moving you.
if you are looking for quality buy the Oppo.if you looking for low quality buy the Philips
OPPO DV-970HD
http://www.oppodigital.com/dv970hd/dv970hd.html
amazon.com $149 shipping free -
Philips makes some cheap DVD player that play most discs. The Oppo is probably a better player though, but you get what you pay for so you should expect that. Even the Oppo won't play "everything". -
Originally Posted by MJA
I have the Oppo 971. It plays the PAL format very well. Oppo is well known for their support and frequent firmware updates to add features, update functionality, and correct issues.
Google is your Friend -
Philips DVP-5960 (~US$70) has a USB1.1 port and can play files off a FAT formatted disks and thumb drives. 8.3 filenames only via USB. And limited bitrate.
It can be made region free with a few button presses. Converts PAL to NTSC, NTSC to PAL. Plays Divx/Xvid.
It's an HD upscaling player but cannot play HD material. There are hacked firmwares available which allow long filenames from DVD, bigger SRT font sizes, etc.
A new model, the DVP-5982, will be out soon. -
About.com's review says that this player can only convert pal to NTSC if the disc was ripped with no region. Is this before the hack?
Originally Posted by esumsea
Thanks Jagabo. Is the Pal conversion rough on this unit. I never heard ofit before but it seems pretty popular here. Does Oppo keep updating their machines?
The 970 also has a USB 1.1 port and accepts media cards,it also supports Divx. -
What do you think of the Pal conversion, Movie Geek? Is there a format or type of disc you have had problems playing with this unit?
Regards,
Mario -
The 5960 isn't perfect. It has several little quirks. Nothing that's a show stopper but little things like:
You can't power on the unit by pressing the Open Tray button. You have press the power button then wait about 7 seconds before pressing the Tray Open button.
It has a resume feature (ie, it remembers where you stopped playing a DVD and can restart from there the next time you turn on the unit) but you have to press the Play button at just the right time after powering up. There's no resume function when playing Divx/Xvid files.
It has no long filename support. It displays about 14 characters of Divx filenames from DVD. It displays 8.3 filenames from USB devices. There are firmware mods that allow for longer filenames from DVDs, but not from USB. 8.3 filenames aren't a problem if your copying one file to a USB thumbdrive to watch it. But if you hook up a hard drive with several hundred videos it's hard to identify what's what.
Note a new model has recently become available, the DVP-5982. As far as I can tell, it's the same as the 5960 but has 1080p output (rather than 1080i) and it's black instead of silver. -
Jagabo, doesn't this (the philips) have the same chip as 970/971?
I believe the Philips 5960 has the same chipset as the Oppo 970 (Mediatek 1389 and 1392), but not the 971.
This is the one:
http://www.hkflix.com/hardware/xq/asp/pid.1/qx/details.htm
They're becoming rather hard to find, but HKFlix does get them in every couple of months or so. Definitely worth the wait and the search. -
Or DVDDL+R. Seems interesting though. Anybody hear anything about this Mediamatics chip or have any experience with this player?
Let me know.
THanks!
Mario -
Just got off the phone with Oppo. Bad news, they say that unless you have an HDMI or DVI input (I don't, I have Yprpb) the Pal to NTSC conversion is not very good. They way it would be slightly fuzzy and choppy. Looking for something that would give me a smooth playback.
Philps 5960 has Component and HDMI and Composite outputs. However only via the HDMI does it upscale. It does look good via component as 4:3 and not 16:9
Went with the DV-696v-s because it has the 16MB pal to NTSC chip and plays aboslutely everything. It does not have Karaokee but who cares! :P
esumsea, I don't know who you talked to at OPPO but they are mistaken. The PAL to NTSC conversion on my 970 is excellent using the composite connection.
Sounds like someone confused upconversion and PAL to NTSC conversion....not that it matters now.
I dunno if it was me you were referring to in being confused (not that I am insulted in anyway). I admit I am a noob but there is no confusing this:
"High power built-in 16MB video converter allows playback of PAL movies on a NTSC TV or NTSC movies on a PAL TV. Basically this DVD player will play any region DVD movie on any TV in the world! "
This is what sold me on the 696v-s. Also it was the assurances of the vendor that the pal playback would be smooth. Oppo simply told me that there was fuzziness and some studdering. I have never tried these units so I had to go with what he said. I did seem like an interesting unit, but if their Pal to NTSC is not going to be reported as great, then I had to go the other way. I will report back my experience with the 696v-s.
Thanks for you comments. They are trully appreciated!
Regards,
Mario
Availability of multi region dvd player in the Philippines
By loster in forum Newbie / General discussionsReplies: 4Last Post: 8th Jul 2011, 12:58 -
DVD multi-region player question...
By mjl1297 in forum Newbie / General discussionsReplies: 8Last Post: 26th Apr 2010, 05:05 -
Multi-Region DvD player, Volume Adjustable
By fitch.j in forum DVD & Blu-ray PlayersReplies: 0Last Post: 31st Aug 2009, 08:41 -
WMV capable multi-region DVD Player
By siluet in forum DVD & Blu-ray PlayersReplies: 13Last Post: 24th Sep 2007, 08:42 -
Recommendation for Multi Region DVD Player/Recorder
By musicandhockey in forum DVD & Blu-ray PlayersReplies: 1Last Post: 20th Aug 2007, 13:41
