Having problems making both VCD + SVCD using 2pass VBR.
Tried different average/minimum/maximum bitrates but the output file stays the same size.
Is this a quirk with my current version of TMGEnc (2.02) or have I got something else wrong?
Trying to reduce average bitrate slightly to fit CD.
XVCD: Do you use a lower avg bitrate than 1150 kbps?
Then select at the system tab Stream type "VideoCD[non-standard]" -
Thanks. That did the trick. I guess standard VCD must buffer the stream to make it standard.
divx 2pass encode error
By ledishis in forum Video ConversionReplies: 3Last Post: 4th Apr 2012, 14:47 -
x264 for Blu_ray: 2pass or crf?
By wiseant in forum Video ConversionReplies: 3Last Post: 2nd Jan 2012, 15:12 -
Is it possible to know if a video has been encoded either by 1pass or 2pass
By ss213 in forum DVB / IPTVReplies: 5Last Post: 11th Apr 2010, 10:04 -
X264:How do you encode in 2pass ?
By themaster1 in forum Video ConversionReplies: 9Last Post: 25th Apr 2009, 17:29 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 03:55
