Hi i have downloaded Lord of the rings, from kazaa, its supposivly a vcd and when open the file it starts to play except i have no visual or sound. It makes me wonder if it is a fake. i have downloaded many codec's and it still will not work. i have alswo downloaded vcd players, like powerdvd and others but it still will not work. The file name is "Lord of the Rings VCD - Ts-CaM - FULL" if anyone has downloaded this file and got it to work can they please tell me how they got it to work. the file properties on it are:
frame rate: 7fps
data rate: 47kbs
width: 320
hieght: 172
Duriation: 2:52:52
videao sample size: 1bit
compression: uncompressed
CAN SOMEONE PLEASE HELP
You've been fooled...
The file is fake, check the resolution it sound kinda wrong...
The internet is crawling of fakes...Magnus Jensen
A.K.A Geezus -
Yep, I think I fell a sucka for that one as well.... But heres a little advise that will save you hours of searching and downloading. Try the "Centropy" version, this has already been encoded into an mpeg and is probably the best quality your gonna get (near dvd rip quality).
Newb Help Please - LOTR Extended Edition
By dpend in forum Blu-ray RippingReplies: 7Last Post: 5th Jul 2011, 13:21 -
LOTR extended editions hits bluray - you buying?
By yoda313 in forum Off topicReplies: 1Last Post: 20th Apr 2011, 08:14 -
Born of Hope - LOTR fan film
By freebird73717 in forum Off topicReplies: 0Last Post: 23rd Jan 2010, 15:19 -
LOTR Bluray preorder now available - theatrical release only for now
By yoda313 in forum Off topicReplies: 3Last Post: 16th Jul 2009, 18:52 -
Multiple DVDs one file(LOTR EEs to be exact)
By filanwizard in forum DVD RippingReplies: 2Last Post: 21st Aug 2007, 23:39
