    Feb 2006
    so this error is pretty common while in eac trying to burn a cue, i've done some googling but still cant seem to wrap around how to get through it successfuly.
    from what i understand the reason this occurs is because an incorrect path or location in the cue? or incorrect song/file name? what i want to know though is what path exactly do i change? because with my cue open in notepad i dont see any paths or locations at all
    (if you could be specific on what it is i need to change it would be appreciated, "file does not exist in line 5.." is whats gives the error here's the first five songs in my cue)
    REM DISCID 39117417
    REM COMMENT "ExactAudioCopy v0.95b4"
    PERFORMER "Miami The Most"
    TITLE "Thizz Radio Vol. 1"
    FILE "Range.wav" WAVE
      TRACK 01 AUDIO
        TITLE "The Symphony (Rydah J. Klyde, Johnny Cash, Peanut & Kata)"
        INDEX 01 00:00:00
      TRACK 02 AUDIO
        TITLE "D-Boyish (Rydah J. Klyde)"
        INDEX 01 04:23:41
      TRACK 03 AUDIO
        TITLE "Black Robbed (Mistah F.A.B., Diesel, Geezy, Bavgate & Don Cisco)"
        INDEX 01 06:20:67
      TRACK 04 AUDIO
        TITLE "Knockout Artist (Fendi Boyz)"
        INDEX 01 11:38:16
      TRACK 05 AUDIO
        TITLE "Golden Shower Up (Keak Da Sneak)"
        INDEX 01 14:07:47
  2. Member gsing's Avatar
    Feb 2007
    Wurstland
    Just a rough guess because I don't use cues that much: you should fill in to the cuesheet the absolute path to where your file (Range.wav) is located. Like "C:\Documentblabvla\My Music\Range.wav" (don't forget the quotes)
    Hope that helps
    Regards
    Feb 2006
    ive tried the "folder location here" then .wav = still no dice
    same error
  4. Member gsing's Avatar
    Feb 2007
    Wurstland
    OK, giving a little more information could help here.
    But first check a couple of things:
    - is the .cue file in the same directory with the .wav?
    if not - copy it there
    - does the file you want to burn really have the name that's indicated by the cuesheet (in line 5, remember) is it really called 'range.wav'?
    if not rename it to this or edit the cue and rename 'range.wav' to whatever your file's name is.
    But maybe you should look at it from a different perspective.
    EAC is actually 'just' a very good ripper for CDA. That's how you should use it (SecureMode, you know that). It was never meant to be a similar exact burning application. In fact it is only working seamlessly with a handful of cd-writers. This is pointed out on the eac-homepage. There are a lot burning apps that handle the problems you are confronted with quite easily, like importing cuesheets or burning two copies of a disc or iso in one go. (That is referring to a another question you asked in another thread).
    'Burrrn' is one, or get 'burnatonce', which is my favourite, because it's not just for audiofiles. They're both free and you should find them fairly easy.
    Regards
