Do SATA DVD-ROM's rip faster than IDE DVD-ROM's? I setup a new computer with a Liteon SATA DVD-ROM and seems no faster than an IDE DVD-ROM.
The max speeds for both PATA and SATA interfaces are way over the max speed of any DVD-ROM drive.
Makes no difference if the drive is "riplocked"; they slow down to 6x max for video "to keep the noise down".
It makes little difference period. The fastest DVD ROM drives are, what 16x? The fastest DVD burners are 18x. That's in the 20 to 24 MB/sec range. ATA100 is 100 MB/sec, ATA133 is 133 MB/sec. SATA is 150 and 300 MB/sec. In all cases the limiting speed will be the drive itself, not the interface.
The biggest reason that SATA DVD ROM drives and burners are being released is that the IDE interface is being phased out by the computer manufacturers. For example, in many Dell Computer systems there is no IDE interface. The system manufacturers apparently want to see IDE go away. Because of this, the drive manufactures have to follow suit or they lose major market segments.
ooooohhhhhh
fazed phased
suite suit
lose loose
Additionally most people will not see any difference between sata i and sata ii (with present hard drives).. (triple chex speling) :PCorned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
how to re-anable my sata icon in win xp sp3 (sata drives not visible in DM)
By deejay.2001 in forum ComputerReplies: 7Last Post: 11th Mar 2011, 09:47 -
can't burn with sata dvd burner
By Shotobits in forum Newbie / General discussionsReplies: 3Last Post: 14th May 2008, 14:53 -
SATA or IDE DVD writer
By m baqar in forum Authoring (DVD)Replies: 8Last Post: 28th Mar 2008, 18:35 -
SATA I cables and SATA II
By HatchetMan in forum ComputerReplies: 5Last Post: 4th Feb 2008, 15:06 -
advice on an SATA dvd burner?
By lumis in forum ComputerReplies: 4Last Post: 19th Jun 2007, 04:09
