I just got Ulead VideoStudio 10 working with Vista. I've installed Divx and Huff codecs. In Ulead however when trying to save as AVI neither show up in the "Compression" dropdown which lets you pick the codec. Both show up in VirtualDub.
Any ideas?
Thanks.
I'm not any help (and a few years late
) but I have the same problem with Video Studio X2 (V12). I ran across this topic searching for answers.
If you're still around and you figured it out, I'd be happy to hear the solution. I'm using Windows 7 64 bit. I only get the standard audio formats to choose from. The standard audio formats are:
PCM
IMA ADPCM
CCITT A-Law
CCITT u-Law
GSM 6.10
Microsoft ADPCM
Anyone?44E -
Rename the file "DivX_ul.dll" in the \Program Files\Corel\Corel VideoStudio 12\ directory
to something like "DivX_ul.dll_old"
This should make it so VS12 doesn't see & use it's own Divx file and use the retail Divx codec instead. -
Perhaps I misread the OP's question. I have a problem with the audio options showing up. I can't output mp3 audio although I have an mp3 encoder installed. According to Sherlock, I have the following installed (among others not listed for the sake of space):
MP3 Decoder DMO
FileVersion = 6.1.7600.16385 (win7_rtm.090713-1255)
CompanyName = Microsoft Corporation
FileDescription = Microsoft MP3 Decoder DMO
InternalName = mp3dmod.dll
LegalCopyright = © Microsoft Corporation. All rights reserved.
OriginalFileName = mp3dmod.dll
ProductName = Microsoft® Windows® Operating System
ProductVersion = 6.1.7600.16385
MPEG Layer-3
FileVersion = 1, 9, 0, 0401
CompanyName = Fraunhofer Institut Integrierte Schaltungen IIS
FileDescription = MPEG Layer-3 Audio Codec for MSACM
InternalName = l3codec.acm
LegalCopyright = Copyright © 1996-1999 Fraunhofer Institut Integrierte Schaltungen IIS
OriginalFileName = l3codec.acm.mui
ProductName = MPEG Layer-3 Audio Codec for MSACM
ProductVersion = 1, 0, 0, 0
If this is now considered a hijack, move it at will.44E -
Grinder, I have no such DivX files in the Corel directory. I have no problem converting to DivX, I just can't get mp3 audio with it.
The only DivX files I found in my entire C drive are Corel installed profiles, such as DivX Handheld, DivX Home Theater, etc.44E
missing mp3 audio codec in ulead when saving as avi
By gabz in forum Video ConversionReplies: 3Last Post: 24th Jul 2011, 16:23 -
Trouble converting AVI(divx)+MP3 to FLV+MP3
By BLboy in forum Video ConversionReplies: 7Last Post: 21st Jul 2009, 04:36 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 12:00 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 23rd Feb 2008, 23:35
