hi 20% of the time i convert movies from ntsc 2 pal, and from xvid 2 dvd.
the frame rate is out by a couple of mili-frames.
For instance, i have an ntsc film 23.976 frame rate, using virtual dub i direct copy the video and change the frame rate to 25.000 Pal, the video is no problem.
But when i direct copy the audio - Save Wav, and use beSliced to save it properly as what is was i.e. vbr mp3 or an ac3 file. After that i run it through beSweets gui and use the ntsc to pal conversion 20% of the time it dosn't always save it as pal 25.000, it saves as 25.001 or 25.003 or 25.004.
I want matching audio and video streams that run at 25.000, i've tried saving it as pcm wave and doing the ntsc 2 pal and saving as a pcm wave before saving as an ac3 and still no luck.
I've tried after converting 25.001 to 25.000 it says its done it but after checking nothing has changed.
Is there any fixes for this, or another program to use to fix it? - thanks!
Best bet is not to do NTSC -> PAL conversion at all, since most PAL players /TVs play/display NTSC material fine.
/Mats -
when doing a xvid 2 DVD conversion should i just pick ntsc DVD profiles then?
Exactly.
Now, not all AVIs are easy to convert to anything, so you may still run into sync problems, but that's another story.
/Mats
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 13:38 -
problem with audio using besweet preset ntsc to pal
By Lynxer in forum AudioReplies: 0Last Post: 24th Aug 2008, 12:30 -
Problems with CMD-850 PAL to NTSC conversion
By vwy33 in forum Video ConversionReplies: 18Last Post: 31st Jul 2008, 08:55 -
Problems with Documentary trying to use both PAL and NTSC footage
By Lucy in forum MacReplies: 5Last Post: 24th Jun 2008, 16:57 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58
