Im looking for a editor that will let me move the audio or video sync a few frames foward or backwards and save to either avi or vob so I can burn to dvd with the off sync tracks. can someone suggest something.
Results 1 to 9 of 9
For avi files, virtualdubmod is pretty easy to use. For VOBs try VideoRedo
Read my blog here.
For which 'input' video? I don't know an editor which could do something like this for any kind of video (mpeg, avi, h264...)
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
I would like to edit the audio or video once I have converted the file from whatever source to a vob file. I use win converter. Keep in mind all I want to do is move the Audio tract back one second or move the video signal up a second and burn to dvd. so when I broadcast over the internet it's all sync for the viewers.
Gunns1linger thanks for your input. VideoRedo did just what I wanted. I was able to offset the audio -523 miliseconds and by surprise boost the volume too. then I save the file with a new name and burnt to dvd. I had someone view the offsync video/dvd from a remote location on the internet. they said it was the best sync that they have seen from another home system. had to waste a few dvd's to lock in on the rate, but it was worth it.
Hey Gunn1inger I dont know how to broadcast a vid from my hard drive so I use dvd's to play through my capture card. also the audio shift is for the viewers over the internet as their is a video delay when playing files.
but playing from my HDD would be hella nice, if I could get some help on that.
You can still use DVD RWs instead of -R or +R discs. That way you can re-burn them if the sync is wrong. That said, your method does seem to be a long way of doing it. Perhaps if you explained the rest of your process someone might help you refine it.
Read my blog here.
Simple Xvid AVI editor?
By tonut in forum EditingReplies: 10Last Post: 12th Jan 2011, 07:10 -
A simple video editor - that works with MKV files (important!)
By jin37uk in forum EditingReplies: 2Last Post: 20th Dec 2010, 22:10 -
Can't find a simple video editor.
By A Traveller in forum EditingReplies: 17Last Post: 28th Mar 2009, 20:05 -
Need a SIMPLE editor for adjusting brightness, etc.
By coyotewrw in forum EditingReplies: 8Last Post: 19th Nov 2007, 12:49 -
Simple Video Editor?
By lilmetal in forum EditingReplies: 16Last Post: 22nd Aug 2007, 21:55
