I have DVD covers on my computer that are for the standard 14mm thick cases. Is there a program that can convert them to 7mm or 9mm thickness automatically, because the DVD cases that I have are the slim ones.
Thanks.
Try CoverXP - free legal download from here
http://www.coverxp.com/main.asp
The included DVD template can be adjusted to work for slimmer cases, and can be saved as a seperate template.
The program has a simple drag and drop interface and can resize covers automatically to fit your template.
It's great !
JCDon't worry.......we'll be alright... -
Here another that has 2 choices of slim dvd cases.
http://www.undercoverxp.tk/Life is like a pothole, you just have to learn to get around it. -
I've just downloaded undercoverXp as recommended by dvdguy4 and run off a couple of test images.
Very impressive, even easier to use than my suggestion.
Nice one dvdguy4, i think i'll be using undercoveXP from now on !
undercoverxp gets my vote too! It seems to compress the middle portion to fit the slimmer case, whilst leaving the front and back (seemingly) unchanged.
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
50 pk slim DVD cases
By zoobie in forum MediaReplies: 0Last Post: 14th Feb 2010, 18:53 -
XMS-100PD Slim Line DVD Player (region free hack inside)
By iceman654 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Mar 2008, 07:55 -
DVD covers
By Seasonal in forum Off topicReplies: 3Last Post: 3rd Mar 2008, 18:30 -
DVD Covers
By Beefer in forum MacReplies: 7Last Post: 15th Nov 2007, 14:17 -
HQ DVD Covers Before There Release
By twiggy99 in forum Newbie / General discussionsReplies: 3Last Post: 11th May 2007, 14:01
