Does anybody else have problems getting the audio to work with the PVR-150 and nerovision or pinnacle studio 9? I have a VCR with composite video plugged into the card along with the left and right audio going into a minijack and plugged into the audio jack on the card. The only program that gets audio is the wintv2000 that came with it. What's the deal?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Not many other programs will be able to get audio from the PVR-150. This is a common problem with hardware MPEG encoding cards. You might as well use WinTV2000. No other program will get any better results either. The video is converted to MPEG on the card. So all programs are doing is saving the data to a file.
Because the card does the "conversion" to mpg in it's hardware, all the capture program need do, is view the source, and tell the card where to save the mpg. Using nero, which is NOT compatible with the card, is pointless.
Use WinTV2k for vhs or dv capture, and gbpvr for TV.Cheers, Jim
My DVDLab Guides
[Hauppauge PVR 150] Any Ways to Live-Record Mic Input AND Line-in Audio?
By darkarn in forum CapturingReplies: 0Last Post: 27th Jul 2010, 20:13 -
Bitrate problem - PVR-150
By m0dts in forum LinuxReplies: 4Last Post: 14th Dec 2009, 13:47 -
PVR-150 poor tv quality
By kaptwan in forum CapturingReplies: 3Last Post: 21st Aug 2008, 15:15 -
WinTV-PVR-150 MCE
By prabha in forum CapturingReplies: 3Last Post: 13th Aug 2008, 10:39 -
Hauppauge PVR 150 compatibility with my OS
By GangstaRap in forum CapturingReplies: 11Last Post: 14th Mar 2008, 10:03
