    Mar 2007
    Hi Easy question is it possible to insert a dvd and then burn the data from it to 2 dvd writers either internal/external or any combo ? Saving burning time so basically doing 2 copies at once ?
    Thanks for your time
    Dennis
    Croatia
    Yes.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    That is a standalone, custom built unit. There are plenty of these around.
    You are limited by the number of drives you connect in a PC, and the ability of the PC to effectively feed them the data fast enough.
    Read my blog here.
    May 2006
    Yes. I have two workstations. Both have two Pioneer A111's. I burn two discs at a time from an image file on my HD. No problem. I have not had a coater in the last 1000 plus burns. I use Instant Copy 7 burning software. Both burners need to be the same make, model and with the same firmware for my software, IC7, to work.
