I cannot seem to extract audio from any movies as I get this error can someone help please
Results 1 to 16 of 16
@ loa909: Open your troublesome AVI file with GSpot and post a screenshot - it'll tell us (and you) what the audio format is.
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Have a read of http://www.goldwave.com/faq.php#mpeg - it states that "[t]o save and create MP3 files the LAME MP3 Encoder must be installed."
John Miller -
I believe - certainly from my experience - that VirtualDub (and VDMod) svae out the original audio, in the original format (i.e. VBR MP3 in this case) and just sticks a WAV extension on the end. No real use. I only found this out recently...Originally Posted by Pinstripes23There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
This happens to you when full processing? In vdubmod you right-click on the audio and switch to full processing, in order to extract to pcm wav. Direct stream will just rename to .wav. That being said I don't use vdubmod to extract to .wav anymore as besweet is so reliable and has never failed me when i do this. Plus it has a faster batch procedure than vdubmod, in case I need to do many at one time.Originally Posted by daamon
I just tried extracting audio using vdubmod on 3 avi files with vbr audio. It worked on 2 and it couldn't with the other, saying I don't have an audio decompressor. Which don't make sense to me cuz they all have the same spec audio and the others extracted just fine. -
That was probably it... Cheers.Originally Posted by Pinstripes23
Carpe diem.
Only in direct stream copy mode, not in full processing mode. Full processing mode will save an uncompressed wave file.I believe - certainly from my experience - that VirtualDub (and VDMod) svae out the original audio, in the original format (i.e. VBR MP3 in this case) and just sticks a WAV extension on the end. No real use. I only found this out recently...
As to the OP's problem. You might want to reset GSpot to it's default settings and try again to see what is opening the MP3 file. Check the audio status to make sure a codec is installed and click the 1 box unde audio to render the audio file.
Lame is an encoder, not a decoder. Fraunhofer should be decoding the file but if you have ffdshow installed, it may be playing your MP3 files.
I have Goldwave 4.26 on my PC and I have no problem opening AVI files with MP3 audio or MP3 music files for that matter. -
Maybe you could reset your options in GSpot to default and repost a screenshot so we can see the information that we are not able to see like rendering and codec status.
You might search your computer to make sure you have L3CODECA.ACM
Here is a link to the Goldwave forum...
http://www.goldwave.ca/forums/viewforum.php?f=2&topicdays=0&start=50
and here is a link to the Fraunhofer MP3 decoder...
http://www.free-codecs.com/MPEG_Layer_3_Codec_download.htm
I notice the file has VBR MP3 but it shouldn't have problems opening VBR since it Goldwave is used to fix VBR audio.
goldwave help
By natty in forum Newbie / General discussionsReplies: 12Last Post: 14th Jun 2008, 02:28 -
goldwave help
By natty in forum Newbie / General discussionsReplies: 16Last Post: 23rd Feb 2008, 03:12 -
goldwave
By natty in forum Newbie / General discussionsReplies: 3Last Post: 16th Feb 2008, 06:25 -
goldwave and wav codec
By natty in forum Video ConversionReplies: 4Last Post: 15th Jun 2007, 08:57 -
looping a track with Goldwave
By thecrock in forum AudioReplies: 2Last Post: 1st Jun 2007, 23:59
