I'm making a menu with in DVDLab Pro and I'd like to use an little Jpeg "Icon" as the selection for various clips. My problem is that I can add the icon, make it invisible when normal yet when it become visible when selected I can only get the icon in one colour. I dont want the highlighted icon , just the Icon itself to appear when selected.
Is this possible ?
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
Switched Menus
Open your menu then in the top toolbar,
Menu>Scene Selection Menu>Switched Menus
And read in the help file under the same.
Although this will not work well with audio or look good with motion menus because it will restart the motion or audio from the start. -
You could also try the Inverse Selection trick talked about here: Inverse Selection Menu
p.s. if you do go with "Switched Menus", then try doing it with Menu Cells instead of separate menus -- response time seems a little quicker with menu cells.
Regards,
George
dvd lab pro - text labels as buttons - problem
By pike8 in forum Authoring (DVD)Replies: 2Last Post: 21st Apr 2012, 07:03 -
Highlight buttons in DvdReMake Pro menu
By c627627 in forum Authoring (DVD)Replies: 3Last Post: 25th Apr 2010, 19:21 -
Proplem with mapping menu and title buttons using DVDit PRO 6
By jakewoodblues in forum Authoring (DVD)Replies: 0Last Post: 14th Apr 2010, 17:56 -
Reliability of DVDLab Pro 2
By Brainiac in forum Authoring (DVD)Replies: 2Last Post: 28th May 2009, 19:04 -
Subtitles in DVDLab Pro 2
By lorix in forum Authoring (DVD)Replies: 13Last Post: 13th Nov 2008, 15:09
