Is bitrate the only thing that affects filesiz? Does using the high quality settings make a bigger file? Thanks.
Wraith
Blow me for faster replies.......
Nope, just the bitrate and the runtime. The size of the source video, the resolution of the source, the resolution of the encoded MPEG, nor high/low motion search affects file size.
Alright, cool. The reason I ask is that I was testing KingViper's and Sefy's SeVCD template. With them both stock, the results were about the same, except Sefy's template bore an 8 something MB file size and the KingViper one was like 9 something, still not a bad compromise. I tweaked it a little bit and it turns out I got a bigger file. I actually lowered the bitrate if anything because it was set at 2000 Constant Quality. Now that little bar above those settings that doesn't affect filesize? Also when I take the disk and put it in my computer, after it is burned to a disk, it says the file is 2.15 MB, that is smaller than the resulting file after conversion, how did I do that?
WraithBlow me for faster replies....... -
the following affects file size-
Bitrate(duh)
RES, if its bigger than source, larger file.
FPS- if its lower than source, it can be bigger but not always(kinda weird)
Ghost reduction at high settings can make file bigger for some reason -
The there are only TWO things which affect the final file size:
1. bitrate
2. runtime
filesize = bitrate x runtime
There only time when things like resolution and video complexity can affect filesize is when you are encoding in such a way such that you don't have CONTROL of the bitrate (e.g., CQ VBR encoding).
If you are encoding in such a way that you can control the max, min and average bitrate, then the average bitrate (and runtime) are the only two things that will affect the resultant filesize.
Regards.Michael Tam
w: Morsels of Evidence -
As I guessed, but you didn't elaborate on that very important point.
If I do a multipass VBR encode where I can set max, min, and avg bitrates, or if I do a simple CBR encode, then things like resolution, video complexity, filters to remove noise, framerate, etc., make absolutely no impact on the final filesize.
Regards.Michael Tam
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 22:43 -
Reduce VOB filesize
By jacktorrance in forum Video ConversionReplies: 8Last Post: 14th Jan 2009, 12:34 -
Reducing filesize
By caper in forum Video ConversionReplies: 19Last Post: 7th Dec 2008, 20:22 -
Question about specific virus that affects USB memory stick
By jimdagys in forum ComputerReplies: 6Last Post: 27th Sep 2008, 00:07 -
Video Capture Device: Cable length question (affects stalling?)
By iwc101 in forum Capturing and VCRReplies: 3Last Post: 18th Sep 2008, 02:09
