A dumb question must surely find a quick answer.
I encode an MPEG-2 file in TMPGEnc 2.5 in 16:9, when loaded into TMPGEnc DVDAuthor it is magically 4:3, burns as 4:3 as well.
Tried to change the header info with IfoEdit as well, but that screwed other things up, some funny flickering, although the aspect ratio was then correct.
Anyone aware of this bug and how to fix it?
Thanks,
Chipsndukes
I think I found my own problem--just proof that every time you load a new source video in TMPGEnc, you should reload the template. This especially applies when you are doing large batches!
Anyhow, it appears the TMPGEnc got set to MPEG-1 when encoding this movie. Don't ask me how, again, what I said above, but I'll reencode MPEG-2, one night wasted, and see how it turns out.
Sorry to be a bother to everyone, thanks for the consideration of this great community, will let you know if in fact the prob. was solved.
Chips
DVD Authoring package that will allow forced (hard encoded) subtitles
By netmask56 in forum Authoring (DVD)Replies: 9Last Post: 3rd Mar 2012, 13:27 -
Authoring DVD frm AVi files using DVDAuthor
By sumit_pankaj in forum Authoring (DVD)Replies: 5Last Post: 19th Jun 2009, 14:01 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 19:37 -
Some DVD authoring programs will not accept CCE encoded mpeg2 files
By ettin in forum Authoring (DVD)Replies: 8Last Post: 18th Jun 2008, 15:57 -
dvdauthor authoring problem (combing 16:9 and 4:3 material)
By ecc in forum Authoring (DVD)Replies: 4Last Post: 5th Jul 2007, 21:14
