Hi, I have a whole load of video files on my computer that I want to play on a portable video player. The videos play fine on the player, but haven't got sound.
Does anyone know of a way i can just recode the audio of a video file, without converting the entire video (because of the time it would take to encode a large number of videos)?
Obviously i would need something that ends up with mpeg layer-3 audio, which is not out of sync with the movie.
Any suggetions are welcome.
Cheers !
Results 1 to 12 of 12
Yeah, sure, but what are the bitrate requirements of the player? Post some info and it'll be easy to make this happen.
It's an Archos AV700, I cpied the specs of the archos website
Video recording: MPEG-47 SP and stereo sound, optimised resolution for TV up to 640x480 @ 30 f/s, in AVI format
Video playback: MPEG-47 SP with B-Frames with stereo sound. Near DVD quality up to 720x480 @ 30 f/s (NTSC), 720x576 @ 25 f/s (PAL), AVI file format. WMV9 (including protected files) up to 352x288 @ 30 f/s, and 800 KBit/s4.
Music recording: From an analog source in stereo sound for WAV (PCM & ADPCM) format.
Music playback: Stereo MP3 decoding @ 30-320 kb/s CBR & VBR, WMA (including protected WMA files), WAV (PCM & ADPCM).
so i guess the last bit is the most relevant, 30-320kb/s?
hope that's what you mean.
thanks!! -
Pretty impressive specs on that player. Don't hesitate to send me one for my efforts, 'mkay ?
Okay, this script should work in most cases. Download and unzip file from the link below. Place AVIs into same folder as the unzipped app -
Note: Your AVI names must NOT have spaces in them
Bad: This Is my.AVI
Good: This_Is_My.AVI
Double Click AVI2MP3.BAT to run.
When Done, the folder will look like this:
AVI2MP3.BAT
example_file.avi
Another.avi
Yet_Another.avi
ffmpeg.exe
lame.exe
mencoder.exe
normalize.exe
ReadMe.txt
New-example_file.avi
New-Another.avi
New-Yet_Another.avi
Files with the "New" prefix are the ones encoded with 192kbs stereo mp3. If you prefer a different bit rate for the audio, open the AVI2MP3.BAT file with Notepad and change the line that starts with the word "Lame". You can't miss it. Also, the script normalizes the audio, so loudness levels should be fairly consistent on the Mp3 encoded AVIs.
Your original AVIs won't be touched at all, so if you aren't happy with the results, no harm done. Of course, remember to remove the AVIs from the folder once you're done doing the audio conversion.
Download Link (5MB)
http://www.bestsharing.com/files/lfKgr246854/AVI2MP3.zip.html -
that sounds awesome! thanks
will give it a go!
your very own archos is already in the post....
might take a while though
seriously though, thanks a load dude. will let you know if any probs with it. -
Right on. Good luck. Lemme know, I'm quite certain we can adjust things if need be
Hi, I have finally managed to find some time to convert the audio on a whole load of avi files, but when i come run it as you say above, i get a "mencoder.exe - unable to locate component" box saying "this application has failed to start because intly.dll was not found. Re-installing the spplication may fix the problem.
then i get a whole load of script in a C:\WINDOWS\system32\cmd.exe box and then the same message again.
then it closes and nothing happens.
any ideas?
much appreciated -
Does intly.dll exist in the zip file Soopafresh provided? If so, is it in a subdirectory within the zip archive? The zip probably needs to be extracted with the folder structure within intact. (Most mencoder/mplayer archives I see usually have at least two subdirectories.)
If cameras add ten pounds, why would people want to eat them? -
Oh, sorry about that
Yeah, I noticed that Mencoder was looking for that .DLL. I'll post an updated one in a minute.
This one doesn't need that .dll file, and it also does better muxing.
http://www.bestsharing.com/files/Iyq7qW270155/AVI2MP3_Fixed.rar.html -
Hi am having trouble downloading the file now, get an error box saying its unavailable or can't be found!! help!
How to convert 5 ch. AC3 to 5 ch. MPEG-2 Layer II
By macman241 in forum AudioReplies: 21Last Post: 1st Sep 2016, 12:08 -
How do you convert the video format from MPEG-layer 3 to MPEG4 SP?
By Conconn in forum Video ConversionReplies: 1Last Post: 2nd Jul 2008, 06:32 -
AVI files - MPEG Layer-3 - audio conversion?
By ChoonyFish in forum Video ConversionReplies: 6Last Post: 7th Feb 2008, 09:27 -
Mpeg-1 Audio Layer 2 - Audio Tag 50 - VirtualDub, TMPEGEnc Can't Read
By Rebooter in forum AudioReplies: 2Last Post: 26th Oct 2007, 22:51 -
MPEG-1 audio Layer 2
By dedine in forum Video ConversionReplies: 4Last Post: 4th Sep 2007, 16:51
