I've got the following equipment to start converting my old family VHS's to DVD;
VCR: JVC HR-S8600E
TBC: AVToolbox AVT-8710 (CTB100)
Now, as I've spent most of my budget on the above two, I can't afford to spend too much on the capture hardware, but at the same time I don't want to be left with a poor quality VHS DV-AVI capture file due to purchasing a poor quality capture card...
1. Will the Ads tech meet my demands and am I likely to get higher quality captures from using more expensive capture equipment such as DataVideo's DAC-100?
2. Do I stream the video from the VCR using an S-Video cable, and the Audio using a Phono cable, and then both the Video & Audio will be fed into my PC along the Firewire cable?
3. Does the Ads tech come with a firewire cable? If not, what cable do I need (how many pins?)
ADS Pyro A/V Link - black screen
By Brad in forum Capturing and VCRReplies: 10Last Post: 20th Oct 2010, 19:23 -
VHS into Imovie (HD6) with Pyro AV Link Problem
By MacInMass in forum MacReplies: 3Last Post: 9th Apr 2009, 08:25 -
Pyro A/V Link w/Elements not recognised by Vista 32bit
By hhhgamewmx7 in forum Capturing and VCRReplies: 12Last Post: 1st May 2008, 19:51 -
Does current ADStech Pyro (firewire) w/Premiere still drop lots of frames?
By miamicanes in forum Capturing and VCRReplies: 9Last Post: 19th Sep 2007, 23:41 -
Component video capture with PYRO A /V Link?
By theinv in forum Capturing and VCRReplies: 2Last Post: 19th Sep 2007, 17:47
