Ok. So. I used to have a progressive scan TV with this combo hooked up, but I no longer have the TV. I'm trying to hook it up by s-video but i can't see the menu to turn off progressive scan. Any help?
If someone could tell me the buttons to press on the remote to change this option, please do. (i.e. "menu, down, enter, down, down, enter, left, etc.")
You need to reset it. Try holding the power button on the unit for 10 seconds, if that doesn't work, try the same thing with the rest of the buttons. Sometimes it's a combination of buttons.
Alright! Thanks a bunch for the help. I completely forgot about resetting the player.
For future reference, for everyone else, to reset the player, hold both the REW and FF buttons on the front panel down for 5 seconds.
BD/DVD Interlace vs Progressive Scan: Which is better?
By Bonie81 in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2010, 06:01 -
Are there progressive scan DVD discs??
By seekt in forum DVD RippingReplies: 33Last Post: 21st Oct 2009, 12:52 -
DVD/VCR Combo Player
By pepegot1 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Feb 2008, 11:41 -
Need help finding a VCR/DVD Combo Player that is CT-2 Friendly
By elling in forum Newbie / General discussionsReplies: 0Last Post: 6th Sep 2007, 18:39 -
Phlips DVP5982 Divx Player Progressive Scan issue
By imakshar in forum Newbie / General discussionsReplies: 9Last Post: 9th Jun 2007, 10:59
