I want to add permanent subtitle to a video and i follow the "How to add permanent subtitle to a video with virtualdubmod" guide, what i want to ask are...why the result movie with subtitle the size is smaller than the original ??
i dont want smaller, if smaller maybe the quality is became worst and i also see the properties of both movie file, the difference is the "Data rate"
what should i do now ?
Thank you....
In the Xvid or Divx configuration dialogs.
video -> Compression -> (select codec) -> Configure
VirtualDubMod Problem??
By 3thman in forum Video ConversionReplies: 14Last Post: 8th Dec 2009, 11:07 -
Virtualdubmod problem....
By aruwin in forum EditingReplies: 3Last Post: 20th Sep 2007, 07:41 -
By Mitchum22 in forum AudioReplies: 0Last Post: 15th Jun 2007, 11:28 -
Help settle a bet...
By SquirrelDip in forum Off topicReplies: 14Last Post: 4th Jun 2007, 01:52
