Hello
I had WMP 10 then downloaded and upgraded to WMP 11. Decided I didn't want WMP 11 as it was causing a few problems so I uninstalled WMP 11. Now whenever I play a .WMV or a .mpg on WMP 10 the sound is fine although the picture is either blank or a few random colours flashing across the screen. If however I reboot everything plays fine although if I break off and do something else and then return to WMP 10 I get the same problems as I have just described.
As far as I know I had all the MS updates for WMP 10 and it played perfectly well until I installed and then uninstalled WMP 11.
Anyone have a solution please?
Many thanks
aw56001
Results 1 to 1 of 1
H264 Playback Problems in WMP 11
By seasonsofwither in forum Software PlayingReplies: 3Last Post: 21st Dec 2009, 23:49 -
Vista Enterprise problems with WMP 11
By jyeh74 in forum Newbie / General discussionsReplies: 11Last Post: 22nd Mar 2008, 20:18 -
WMP 11 problems?
By rmunk in forum Software PlayingReplies: 2Last Post: 10th Dec 2007, 15:50 -
WMP
By marlo in forum AudioReplies: 0Last Post: 23rd Nov 2007, 16:50 -
Audio Sync problems with MKV file using WMP
By jradams76 in forum Software PlayingReplies: 0Last Post: 23rd Jul 2007, 12:51
