I'm looking for the best software to use. Here is my pretty much only purpose.
I have a DVI Tape Camcorder that we record home movies on. We have a newborn so it's being used much more often now.
I want to be able to create some quick DVD's with some decent special effects as far as menus etc goes.
A friend showed me IDVD one time on a mac and I liked how you could pull up a template and drag a movie into a frame and there it was.
I'm not looking for the most professional in the world but something that looks pretty good that allows me to add customer background music to menu's with some good templates.
Since I have quite a few and I"m sure that's not going to change I don't want to spend days working on one tape so I wanted something that had a few templates that could be semi tweaked to look good like IDVD seemed to be.
My current PC specs are:
Windows Vista Ultimate
Pentium D 3.2 Ghz
Nvidia Geoforce 6600 Video Card
2GB RAM
500 GB HDD
So you see the software will also have to be compatible with Vista which might hurt I know.
accounting software for Mac bookkeeping software for Mac
By Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 13:43 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 03:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 08:07 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 21:45
