i'm trying to do episodes from avi to dvd i have 18 episodes 750mb per file.
and when i'm converting avi to dvd when it comes to 50% my pc is turning off like when it goes the lite
I triad 3 programs
Winavi
NeroVision
and same problem.
with VirtualDub i tried to convert from xvid to divx
and same problem
Very likely overheating. Check your CPU cooling system for blocking and dust.
/Mats -
1. See mats answer
2. Defragment hard drives
3. If still a problem - remove CPU cooling, clean heat block, etc., re-apply thermal paste, re-install.
4. If still a problem, you may have to go into BIOS and make the CPU run slower - only your motherboard manufacturer can tell you how to do that!
I had a similar problem with DVD Rebuilder encoding with CCE, and had to go all the way to step 4 recently. I already know that I need to replace the motherboard on the machine, but haven't had the time to do it. I do have a backup built - but haven't installed all the software to run it.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
Audio isn't playing out both speakers after turning VHS into a DVD...
By littleBIGworld in forum Newbie / General discussionsReplies: 4Last Post: 19th Feb 2011, 02:44 -
turning multiple avi files to dvd
By videodude1966 in forum Video ConversionReplies: 1Last Post: 23rd Dec 2010, 19:32 -
turning subtitles OFF
By john999 in forum Newbie / General discussionsReplies: 3Last Post: 16th Jun 2008, 14:05 -
turning up volume
By mainegate in forum ffmpegX general discussionReplies: 0Last Post: 27th Aug 2007, 02:03 -
Turning DVD chapters in to MP3 or wave files
By ericshogan in forum DVD RippingReplies: 7Last Post: 8th Aug 2007, 17:03
