Results 1 to 12 of 12
    Mar 2007
    Hi all
    Thanks for coming in to help,the prob i have is i have a set of mike tyson dvds all his fights on 12 disks,the prob is each fight isnt in order and i would like to get each fight off the dvds and put them in the right order,i have TMPGEnc_DVD Author_v21577_Retail is this any good for the job and if so any chance someone can help with step by step instructions or any help at all please,i have tried myself and it failed misrably,now i am not up on this sort of thing at all as i have never done anything like this before,but i int a complete moron when it comes to pcs....so if u have the time and energy and u can help i will be very very greatful..
    so many thanks in advance for any help..
    thanks
    Hippy
    Apr 2004
    Miskatonic U
    Rip them with DVD Decrypter, use the Add Video function in TDA to add the fights in the order that you want them, then create the new disc. You may find that they are too large, in which case you can use DVD Shrink or DVD Rebuilder to bring the size back down.
    Read my blog here.
    USA
    hippy007, please use a more descriptive title in your posts. 'Help help oh yeah and heeeeelp please:trying to make a dvd' is not descriptive of the subject and makes future searching for your subject impossible. I will change it for you this time.
    Moderator redwudz
  4. You can rip them seperately with Decrypter and open Shrink and add the folders in any order you want. When one Shrink is full or to the compression you allow, rip it, close and start with Shrink for the rest. Pretty simple. By that I mean I was able to do it 1st time trying.
    NL
    Mar 2007
    Well thanks gun for advise i will try it good man
    soz red and thanks for changing it,and i see ya point lesson learnt,bloody newbies hay lol
    nitelite cheers for ya response bud and i like the fact u said quite easy well u did it frirst time {it mean it must be easy lol}only kidding infact u have now put presure on me because if i cant do it u are going to think i am a right dumb arse lol...thanks again for advise m8
    THANKS ALL AGAIN FOR YA HELP GOOD STUFF
    Hippy
  6. I'm a huge boxing fan. And also have a Tyson career set that is not in chronological order.
    You do not need to rip them with DVD Decrypter, these are unprotected DVDs.
    Is the menu a shade of blue with no pictures, sort of layed out like a school notebook?
    If so, its the same set I have and it was created with a Panny DVD recorder.
    Just copy the VOBs to you hard drive then use TDA and add each video file(VOB). BTW, I have TDA and have wanted to do this with my Tyson set for yrs now.
    Mar 2007
    Hi pinetop yes m8 it is a shade of blue with no pic so they do sound like the same ones u have,thanks for the advise,i will give it a go over the next couple of days and see how i get on{so watch this space},if it all go well and good u will have to give us ya email addy maybe i can send u a set
    cheers again
    Hippy
    Mar 2007
    Right excuse my ignorance here,but when u say add vob file to tda i take it each vob file is a fight and i have to put them into tda in the order i want them?and if this is right is there anyway i can veiw a vob file as a fight so i know which fight is which instead of having to keep putting the disk back in my dvd to veiw it....thanks
    Hippy
    Mar 2007
    Also i have just tried to add a vob file to tda and they dont not show up in the folder it is blank when i look in it,then if i change the drop down box to all files they show up but when i try and open one of them in comes up with the pal dvd video standard does not accept meg-2 with resolution of 70x480
    and
    the pal dvd video standard does not accept a framerate 29.97fps
    i am using tda version 2.1.5.77,it did say goto souce wizard and do it from there but that didnt work either,any ideas boys and gals??thanks
  10. Mod Neophyte redwudz's Avatar
    USA
    Unfortunately, the main movie VOBS are just what results from the video being split into 1GB sections. Scenes may overlap into two VOBS.
    Take a look to the upper left on this page for 'WHAT IS' DVD to see the DVD format and specification. If you want to do editing like moving scenes around, you can use something like the freeware VOB2MPEG to create one large continuous MPEG from the VOBS that will contain the whole movie file for editing. Here's one guide: https://www.videohelp.com/forum/viewtopic.php?t=224833
    You can also add the whole VIDEO_TS folder to TDA, then just move the chapters around, then reauthor. But if I need to do a lot of editing, I use VOB2MPEG and edit the MPEG file in MPEG Video Wizard.
    You can play back a VOB file with many software players, VLC Media Player for one. Then you would see where it is split.
    But if you also have to do a framerate conversion from PAL>NTSC besides, you have a lot more work to do. You will probably end up losing all the menus and chapters and just have to reauthor it all. Framerate conversions guide: https://www.videohelp.com/convert#4;41
  11. Member classfour's Avatar
    The Heartland, United States
    TDA should do what you need - you may have to do some work and determine the order of the discs.
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
    Mar 2007
    thanks red very helpful will have another dash at it over the next few days and see how i get on,i think they r all pal so sould be ok on that front...
    thanks again m8
    hippy
