How can I author a 720x576 interlaced file into VC-1 or AVC and burn it onto a normal 4gb DVD but authroed as a Blu Ray disc. I heard that this can be done and get a lot more video with the same quailty on a standard disc.
Try latest Ulead DVD Moviefactory...or maybe it was only hddvd on dvd media.
I've only heard of people being able to author HD-DVD to DVD discs. Maybe it's possible to do that with BluRay, but I don't know. I know that the HD-DVD format does support HD-DVD content on DVD discs. I don't know if BluRay does or not. The forums at
http://www.doom9.net
might be of some use to you as they have some people there who might be trying stuff like this.
I'm not sure I'd say "a lot more video" is accurate. VC-1 saves some space, but some of the stats I've seen suggest that the space savings are only about 20% over conventional MPEG-2. If that is accurate (I have no idea if it is or not), then you're not going to be able to work miracles by moving to AC-1.
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 23:18 -
Copping Disc - Disc Data Recovery Software.
By Teac23 in forum DVD RippingReplies: 5Last Post: 1st Oct 2010, 21:06 -
Copying,Copied DVD-Rw disc to,DVD-R disc
By 306james in forum DVD RippingReplies: 3Last Post: 12th Nov 2007, 12:45 -
Copying, Copied DVD-RW DISC TO DVD-R DISC
By 306james in forum FeedbackReplies: 2Last Post: 12th Nov 2007, 05:44 -
Is it possible to rip a HD DVD disc to Hard Disc ?
By fjmr in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2007, 13:50
