    Feb 2007
    Brazil
    Hi folks,
    when I was using Premiere 6.5, it was easy to select progressive scan to capture DV recorded on that format.
    But on Premiere Pro 1.5 I just can't find it... do you know where do I select progressive scan for capturing? Thanks!
  2. When starting a project, choose "No Fields (Progressive Scan)"
    Feb 2007
    Brazil
    Thank you so much Guiboche. I was used to go to the settings tab, because of the 6.5 version.
    I do have another question: I have some footage on mini-DV but I'm not sure if it was shot on progressive mode or interlaced mode. Is there any way of finding out? Or just looking at it and knowing it? Sorry for the poor english.
  4. You should know by looking it it.
    Put the preview window to "100%" instead of "FIT" and it should show you the full 480 lines of resolution. If there's combing, it's interlaced.
