Why file size is smaller after audio delay changing process?
If you mean AVI-Mux GUI, it can use less overhead than other avi muxers. You lose out on compatibility though, so you might want to disable those options.
Easiest probably is to load one of the stand alone profiles (mp3 or AC3).
Only partial audio after using AVIMux
By neomaine in forum Video ConversionReplies: 3Last Post: 11th Feb 2008, 18:07
