Hey, gang.
I've made a before-and-after weight loss morph video with Sqirlz Morph.
The images involved were shot in portrait dimensions -- high rather than wide.
Playing back the resulting video on the PC looks fine -- Media Player doesn't mind that the vertical dimension is the long one. But when I uploaded the clip to YouTube, of course, it stretched the horizontal all the way, distorting the video and making me look big 'n wide...naturally defeating the purpose of posting the weight loss clip, y'see.
I plan to include this and other morphed-from-portrait videos in a longer video.
I'm guessing the solution is to pass the video created by Sqirlz Morph through some other program to create a new 4:3 file with black borders on either side of my original video so I can work with it like any "normal" video.
If true, I'm n00b enough not to know what (simple) program would be most appropriate for such a task.
Thoughts?
Thanks.
Open the video in Virtualdub. Click on Video -> Filters and add the Resize filter. In the top section enter the dimensions of the video as it is now, so it doesn't change. Tick the box for Letterboxing, and in the bottom section, enter dimensions to make it square pixel compliant. eg. 640 x 480. This will add black vertical borders to the image. Click OK until you are back at the main virtualdub screen. Test it to make sure it looks OK, then click Video -> Compression and select a codec and configure it (YouTube likes Xvid < 100 MB) and create a new video.
Note : The dimensions you will enter into the resize filter depend on what the current dimensions are. As you haven't posted any, I have only given you an example. You need to adjust accordingly.Read my blog here.
Thank you for the advice, sir. I'll give that a go. Much appreciated.
What are Video "Profile Formats" or "Levels"?
By HanDuet in forum Newbie / General discussionsReplies: 2Last Post: 16th Mar 2011, 00:41 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 18:45 -
Removing bad segments using program "Video Edit Master"
By risp73 in forum Newbie / General discussionsReplies: 0Last Post: 30th Aug 2008, 16:52 -
Need some help with "dubbing"/"muxing" video with audio
By FSSSWE in forum Newbie / General discussionsReplies: 9Last Post: 21st Jun 2008, 19:49 -
Who made Maxell MIJs? And Difference between "Pro" and "Valu
By mrlar2 in forum MediaReplies: 4Last Post: 10th May 2007, 16:55
