I work at a school that needs to record video on performances of 5-20mins sessions. Our setup at the moment is as follows: we have a DV camcorder connected via firewire and/or composite to a Sony DVD recorder. We've had this sort of system for about 2 years now, having moved from VHS tapes. Can anyone suggest an alternative? It must be simple, easy to use and record on portable media like flash memory sticks. I looked at SanDisk V-Mate which doesn't seem up to the job. I tried capturing to PC via firewire but it's a hit and miss with the audio sync. Any thoughts are greatly appreciated.
AVerDVR EB1304 MPEG4+
or
build your own w/ the AverMedia AVerDVR NV3000 card"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I've been using a JVC Everio GZ-MC200 camera/camcorder to record my son's basketball games this year, and in good lighting conditions, it's perfect.
This model records to compact flash (4GB) or SD media (2GB), up to 5hours (not recommended for quality reasons) in extended mode, 1 hour (4GB) in high quality (better than standard DVD) mode.
If you shop around ebay, you can pick them up pretty cheap (under $200).
They do appear to be fairly sturdy, especially compared to the chinese MP4 cameras that I've had my hands on; and are not made as lightly or compact as the Panasonic MP4 recorders.
The current model is the Everio GZ-MC550 or something like that.
I'd also recommend looking at the JVC hard drive models, but you'll have to run those with a firewire to get the video off - I just use my printer to read the CF and SD cards, change the .mod file to .mpg and you can author with TDA or your favorite authoring program.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
Is there a hardware/software combination that can capture Anamorphic TV
By Phuzzy in forum Capturing and VCRReplies: 9Last Post: 27th Oct 2011, 06:30 -
Capture Artifacts - Hardware or Software?
By jday in forum Newbie / General discussionsReplies: 10Last Post: 10th Jul 2010, 11:08 -
Recomended Software for fast simple compatible capture and conversion
By The Turtle in forum Newbie / General discussionsReplies: 1Last Post: 28th Apr 2010, 16:10 -
Need Vista64bit capture hardware/software...
By nhgawe in forum Capturing and VCRReplies: 1Last Post: 19th Apr 2009, 17:26 -
Help-Software that can capture closed captions from tuner for a simple user
By videohelpkg in forum SubtitleReplies: 1Last Post: 22nd Jan 2009, 16:01
