I'm planning on popping a new hard drive in soon. I'm wondering if, using TMPGEnc, i read the source from one disc and write to a second if things will be faster. I know the bottleneck is usually the CPU speed for encoding, but in this case i'm only using the merge/cut tools, so no real encoding (i.e. AVI to MPG) is taking place.
I'm running dual Athlon MP 1600+'s with 512 DDR RAM,
IBM 60 GXP HDD's (two of them)
Thanks!
Results 1 to 9 of 9
I too run dual-IBM 60Gig drives (spanned together as a single 120Gig NTFS volume). Reading from a drive and writing to a physically separate drive will always be faster than reading/writing a single drive. Since your planning on doing it anyway, there will be no loss, but maybe 1 minute saved at most. If you were debating, I would say don't waste the $$. But you'll try it anyway, so just try it and see what happens
Thanks for the quick reply! I'll have two drives anyway, so i'll give it a try. I imagined the time difference would be present, yet relatively insignificant.
Hi guys
Both of you are running dual amd, I am planning to buy dual mp1800+ next week.
Is everything working fine with this dual cpu's, or do you experience more crashes than normal?
Is the encoding speed ok?
Doo you have a problem with the cpu's going to warm?
Thanks -
Definitely, especially if your two drives are on separate IDE channels. When doing things like muxing, cutting, etc., the bottleneck is your disc access speed.Originally Posted by MunDMC
Regards.Michael Tam
w: Morsels of Evidence -
Yes, it will be significantly faster. I use dual WD400BB's in RAID0 in addition to a 15.3 gig Western Digital capture drive, and it is significantly faster. Also, get tons of RAM (256MB min.), although it will help less than a secondary hard disk.
Encoding for faster streaming and MP4Box ?
By Miata in forum Newbie / General discussionsReplies: 2Last Post: 31st Jul 2010, 20:57 -
Is encoding ur file unto another HDD faster?
By jones24 in forum Newbie / General discussionsReplies: 6Last Post: 15th Aug 2009, 18:45 -
How do I get faster encoding time from quad-core processor?
By nick101181 in forum Newbie / General discussionsReplies: 5Last Post: 26th Oct 2008, 15:54 -
Do newer drives rip dual layer discs any faster?
By Sephiroth666 in forum DVD & Blu-ray WritersReplies: 3Last Post: 21st Feb 2008, 10:40 -
Increasing Encoding Speed?? What Hardware makes it run faster?
By sandman423 in forum Newbie / General discussionsReplies: 15Last Post: 25th Jan 2008, 23:09
